ᐅ Floor Plan for a 160 sqm Single-Family Home – Suggestions for Improvement?
Created on: 15 Sep 2018 19:29
bbkhacki
Development Plan
Development Plan: Yes, available.
Restrictions: Knee wall height (0.8 m; 1.3 m stated in building inquiry), roof pitch (25-38°, dormers from 35° onwards), plastered facade with fine-grain plaster
Plot size: 1049 sqm (11,293 sq ft)
Slope: No
Site coverage ratio: 0.4 (general residential area)
Floor area ratio: 1.2 (general residential area)
Building envelope, building line, and boundary:
Edge development:
Number of parking spaces:
Number of floors:
Roof type: Gable roof
Architectural style: ?
Orientation: ?
Maximum heights/limits: ?
Other requirements: ?
Architectural style, roof type, building type: Swedish log house
Basement, floors: 1.5 floors with basement
Number of occupants, age: currently 2 persons (both 29) + 1 child from March 2019
Room requirements on ground and upper floors: see floor plan
Office: to be used as a home office and, if needed, as a guest room (sofa bed)
Overnight guests per year: approx. 10
Open or closed architecture: still open, tendency towards open architecture
Conservative or modern design: conservative, Swedish house
Open kitchen, kitchen island:
Number of dining seats: 6 (extendable table; then 8-10 seats)
Fireplace: yes, masonry stove or fireplace in the living room
Music/stereo wall: no need
Balcony, roof terrace: no need
Garage, carport: 2 parking spaces as carport on east side
Kitchen garden, greenhouse: vegetable patch and possibly a small greenhouse in the garden later
Designer: So far self-designed, based on show homes and catalogs.
Price estimate according to architect/planner: no estimate yet
Personal price limit for house including fixtures: 350,000-400,000 (plot already owned)
Preferred heating system: district heating
The current draft was created based on various show homes and manufacturer catalogs. What I liked well in the show homes has been incorporated into the floor plan. For example, the bathroom design in a T-shape; shower and toilet are hidden left and right behind the T. Unfortunately, my current drawing tool does not allow furnishing. I have to print the plans and add furniture layouts by hand. A furnished floor plan will follow.
I think the floor plan shows the intended rooms and the desired space requirements.
I hope this now provides a better working basis!
Grundriss eines Hauses: Wohn-/Essbereich, Küche, Diele, Speis, WC/Du, Gast, Arbeiten.
2D-Grundrissplan eines Gebäudes mit rot markierten Bereichen und Beschriftungen
Grundriss einer Etage mit zwei Kinderzimmern, Bad, Schlafzimmer mit Ankleide und Galerie.
11ant19 Sep 2018 21:40
bbkhacki schrieb:
I’m just not quite sure how to get from working through everything to the desired floor plan...
As counterintuitive as it may sound, the shortest way is to create some distance first. That means during the phases of your internal reflection, you should put away the catalogs for about three to four weeks (just deciding not to touch them is not enough; the physical act of putting them away is part of the process).
bbkhacki schrieb:
or should I just give up
At this stage, yes, it’s best to pause.
19 Sep 2018 22:42
Phew... just placing the sofa...
bbkhacki
20 Sep 2018 07:37
Development Plan
Development plan: Yes, available.
Restrictions: Knee wall height (0.8 m; 1.3 m is included in the preliminary building inquiry), roof pitch (25–38°, dormers allowed only from 35°), plaster facade with fine-grain plaster
Slope: No
Floor area ratio (FAR): 0.4 (general residential area)
Plot ratio: 1.2 (general residential area)
Building window, building line and boundary:
Edge development:
Number of floors:
Orientation: ?
Number of occupants, age: currently 2 people (both 29) + 1 child from March 2019
Space requirements on ground floor and upper floor: see floor plan
Office: used as home office and guest room if needed (sofa bed)
Open or closed layout: open yet to be decided, leaning towards open layout
Conservative or modern construction: conservative, Swedish house
Number of dining seats: 6 (extendable table; then 8–10 seats)
Fireplace: yes, masonry heater or fireplace in the living room
Music/stereo wall: not needed
Balcony, roof terrace: not needed
Utility garden, greenhouse: vegetable bed and possibly a small greenhouse later in the garden
Designer: So far self-designed, based on show houses and catalogs.
Cost estimate according to architect/planner: none yet
Personal price limit for house including fittings: 350,000–400,000 (plot already owned)
The current design is based on various show houses and manufacturer brochures. What I liked in the sample houses has been reflected in the floor plan. For example, the bathroom layout in a T-shape; shower and toilet are concealed on the left and right behind the T shape. Unfortunately, my current drawing software does not allow furnishing, so I have to print the plans and add furniture by hand. A furnished floor plan will follow.
I believe the floor plan shows the intended rooms and desired space requirements.
kbt09
20 Sep 2018 08:00
A bit better, but it would be even better to add this to post 1 of this thread (if it’s still possible, which should be the case recently), so it can be found more quickly.
Also, a site plan of the property is missing, preferably oriented to true north and including some measurements.
kaho67420 Sep 2018 08:34
The thread is slowly getting interesting. What does the plot of land look like? A site plan would be really helpful. 350,000 to 400,000 – with a basement, that might be tight. Do you really need it? What will you put in there?
11ant20 Sep 2018 13:57
bbkhacki schrieb:
Roof pitch (25-38°, dormers etc. only from 35°)
The specifications were probably filtered through several layers of approval.
bbkhacki schrieb:
Floor area ratio: 0.4 (general residential zone)
Plot ratio: 1.2 (general residential zone)
This would suggest the possibility of three full stories (?). Do both figures apply to the same building plot?
