ᐅ Floor Plan: 150 sqm Single-Family Home with Separate Apartment – Carport/Garage and Shed/Workshop
Created on: 21 Apr 2022 23:54
sysrun80
Plot size: 823 sq m (8,860 sq ft)
Slope: No
Floor area ratio: 0.3
Plot ratio: -
Building setback, building line and boundary: 5 m (16 ft) all around
Edge development: -
Number of floors: 2
Roof style: Gable roof, 25 degrees
Architectural style: ?
Orientation: See drawing
Maximum heights / limits: acceptable
Other requirements: -
Number of people, ages: 2 (42, 44)
Space requirements on ground and upper floor:
Office use: Family use or home office? Home office
Guest overnight stays per year: A few
Open or closed architecture: Open
Conservative or modern construction: Mixed 🙂
Open kitchen, kitchen island: Sort of
Fireplace: No
Garage, carport: See plan
Designed by: - Do-it-Yourself
Small utility room with washer/dryer on the upper floor
500k – furniture and kitchen available
Preferred heating system:
Air-to-water heat pump + central ventilation
Why did the design evolve the way it did?
We plan pragmatically and practically. It should appeal to us and not be a showpiece for the Rotary Club friends.
General tips and info specifically regarding room sizes. We are still a bit uncertain.
Ground floor plan of a house: living room, kitchen, garage, garden, compass.
Second floor plan of a living area with bedroom, office, gallery, and bathroom; compass on the right.
Isometric 3D top view of a single-family house with garden, terrace, garage, and two cars.
Isometric house floor plan view: garden, terrace, garage with cars, kitchen, living room.
3D top view of an apartment: living room, kitchen, bathroom, bedroom, hallway, and workspace.
Isometric 3D view of an apartment with bedroom, living room, kitchen, bathroom, and hallway.
sysrun80
2 Jun 2022 00:29
Thanks for the input @ypg 🙂
The access to the bathroom on the upper floor is non-negotiable – my wife wants direct access... I’ll experiment a bit with that tomorrow.
In the meantime, I have already made some changes to the ground floor:
Floor plan of a house: open living/dining area, kitchen, bathroom, guest room, utility room, garage.
The guest room is now located in the northeast corner. The toilet now has a "hidden" entrance. I just noticed I forgot to include a window there...
The kitchen is now open.
The "TV corner" is now in the southwest corner. However, I’m concerned it might feel quite cramped there.
kbt09
2 Jun 2022 06:48
@sysrun80 ... if it’s not possible to orient the plans to north, then having a north arrow on each sketch would be quite useful ... that way the situation can be understood much more quickly.
Your plan includes a dead-end hallway, which wasn’t necessary at all in Yvonne’s plan, for example. On the upper floor in Yvonne’s design, there is still room to adjust—especially by changing the direction of the staircase (stairs leading up from the living area)—you could convert the entire right-hand side of Yvonne’s upper floor into a private suite.
Is there a reason why you want to drive into the garage from the side like that? Essentially backing out around a corner onto the street?
K a t j a2 Jun 2022 07:33
Sorry if I missed it, but why does the guest have to be downstairs? In my opinion, the design would be much more efficient if the guest sleeps upstairs.
sysrun80
2 Jun 2022 08:40
kbt09 schrieb:
@sysrun80 ... if it’s not possible to orient the plans to the north, then having a north arrow on every sketch would be quite helpful ... that way you can quickly understand the layout.
The last plan has it in the upper third, in the middle – unfortunately quite small.
kbt09 schrieb:
Your plan includes a side hallway, which wasn’t necessary at all in Yvonne’s plan, for example. On the upper floor in Yvonne’s version, there’s still room for adjustments, especially by rotating the staircase direction (stairs going up from the living area), you could convert the entire right side of Yvonne’s upper floor into a private suite.
Is there a reason why you want to drive into the garage from the side like that? So basically reversing around the corner onto the street?
What do you mean by rotating the staircase direction? Currently, the stairs go up from the living area.
The options for driveway access are unfortunately quite limited. We’re already reversing onto the street now. That’s not a problem since the street is a dead-end.
K a t j a2 Jun 2022 08:57
Too little information. Is access from the north via the main road also possible? If so, why do you definitely want to park on the west side? What are the approximate dimensions of the plot? What are the exact dimensions of the building envelope? Are garages allowed outside the building envelope? What setback from the street is required for garages? "Fits" is too vague for the maximum height. What floor-to-ceiling heights are planned? The question in #33 remains unanswered so far.
sysrun80
2 Jun 2022 09:35
Here is a site plan showing the current situation.
Cadastral map: pink dashed boundary of parcel 340; surrounding buildings.
Is access from the north via the main street also possible?
No
See plan
Regarding the building envelope, I only have the information: minimum 3 meters (10 feet) distance, and from a total building height of 6 meters (20 feet) upwards, always 50%. For example, if the house is 7 meters (23 feet) high, then 3.5 meters (11.5 feet) distance applies.
3 meters (10 feet)
What floor heights are planned?
Ground floor rough height 2.75 meters (9 feet), upper floor knee wall height 2.00 meters (6.5 feet). Roof pitch 25 degrees.
Question in #33 remains unanswered: "Why does the guest have to be downstairs?"
Because "upstairs" is meant to be private.
