we are currently planning the floor construction for our house renovation.
The house is a bungalow with a partial basement.
We removed the screed and insulation because we want to install underfloor heating and proper insulation. The base floor structure has varying heights; the basement rooms are higher than the non-basement ones.
The current plan is as follows:
1. Styrofoam screed as leveling fill to bring all rooms to one level
2. On top, 5cm (2 inches) Austrotherm Resolution insulation boards
3. On top, Uponor Classic vapor barrier, then a wet system underfloor heating
4. On top, a traditional heated screed layer of 6-7cm (2.5-3 inches) (final thickness to be determined by the screed contractor)
5. Floor covering
My question is: Does anyone here have experience with Austrotherm Resolution floor insulation boards for thermal insulation? Or comparable rigid foam insulation products with resol foam? I am concerned about the product specification, which states a compressive strength of only 30 kPa (3 t/m2) at 10% compression, while I have seen values ranging between 100-300 kPa elsewhere. Is the 30 kPa rating realistic?
According to the manufacturer, this product is intended specifically for use as insulation under screed. I have already contacted the manufacturer to check if the value on the website might be an error.
Thank you very much and best regards,
Eike
5. Floor covering
Eike
nordanney5 Jan 2021 17:43I would not use that. I am currently installing 20mm (0.8 inches) aluminum-coated PUR foam. It also has a thermal conductivity of 0.022 W/(m·K) and a compressive strength of 100 kPa. Resol foam is much more sensitive and does not tolerate moisture well.
