ᐅ Flooring on the step between the garage and the outdoor area
Created on: 4 Mar 2025 12:06
MR___MR
MR___MR
4 Mar 2025 12:06
Hi,
as you can see in the pictures, I have the problem that the step is lower than my paving.
Now the question is, what kind of surface solution can be applied in this situation?
One option I considered is using a natural stone slab and grinding the front so that it aligns with the paving. However, I’m uncertain because the natural stone slab can be no thicker than about 10mm (0.4 inches) to remain stable.
Bodenansicht vor einer blauen Tür: Rauher Betonboden mit Kies und Putzresten.
Näherer Blick auf rauen Betonboden mit Kies, am oberen Rand liegen Steinplatten.
KlaRa4 Mar 2025 19:18
Well, the "problem" is actually not a problem—at least not an unsolvable one.
Without going into other options: since the natural stone slab you mechanically "pre-treated" will later be directly bonded to the concrete substrate, the material thickness of 10mm (0.4 inches) is not an issue.
This is because no bending moments can act on the natural stone under compressive load from above.
The natural stone immediately transfers the applied compressive force through the adhesive layer to the concrete.
In other words: it will work the way you are thinking.
Best of luck: KlaRa
MR___MR
5 Mar 2025 08:54
And if I want to let the slab cantilever 10 to 20mm (0.4 to 0.8 inches) like with the window sill, will that still be stable?
KlaRa5 Mar 2025 11:19
You can find the answer to your question in my post!
There, I explained that the natural stone slab will later be bonded directly to the concrete base, so no bending stresses can occur as a result. If the natural stone slab overhangs at a thickness of 10mm (0.4 inches), that edge will definitely break under load.
Solution: support the overhanging part with a compressive mortar strip.
KlaRa6 Mar 2025 10:02
KlaRa schrieb:
support with a compressive-strength mortar strip
This means: apply a strip of compressive-strength mortar (which you can get at any hardware store) underneath the cantilever on the concrete (in case my explanation was not clear enough), and then place the natural stone slab on top of it.
MR___MR
6 Mar 2025 10:17
I’m going to go with no cantilever and choose tiles instead.
