L75igf9es-123 Apr 2013 13:49Originally, we had agreed on a pitched roof with the general contractor/architect. In the end, it became a flat roof. The general contractor/architect then recommended a "canopy" as facade protection, which is clearly shown in the plans attached to the general contract (see attachment: Extract from cross-section plan according to attachment to the general contract). There is actually nothing documented in writing regarding the roof.
According to the attached cross-section plan, the canopy was supposed to extend 30cm (12 inches). Yesterday, the metal cladding was installed. Instead of the planned 30cm (12 inches), it now only extends 5-6cm (2-2.5 inches). I immediately raised an objection. The general contractor/architect just said that no "canopy" was agreed upon. How relevant are the plans? Can the general contractor/architect just do whatever they want?
Thank you again!
Thank you again!
MODERATOR24 Apr 2013 11:20The contract must clearly specify in writing which construction services are to be performed, including their type and quality. Construction drawings are usually considered supplementary or represent one possible execution method, which must be agreed upon in writing.
Contracts often include a hierarchy that determines the order of precedence and relevance of all documents (plans, written agreements, standards, etc.). It typically reads something like this:
"In case of disputes or contradictions, the following documents apply in order of priority:
1. Construction description
2. Technical contract specifications
3. Construction drawings..."
Do you have a similar clause in your contract? It might be helpful if the “construction drawings” were placed at the top of the list.
Richard-130 May 2014 11:55This is often heard—that agreed-upon services are simply not delivered. In the case described, this is clearly true. There is really a feeling that they can do whatever they want. I just find this unbelievable.
