ᐅ Fixed glazing in uPVC windows leaking
Created on: 10 Jan 2023 20:33
B.Baumeister
Hello everyone
This concerns a solid construction house built in 2018/19, where I have PVC windows.
One of them is a two-sided casement window, connected at the bottom to a fixed glazing panel running the entire length.
So, at the bottom there is floor-to-ceiling fixed glazing about 2m (6.5 ft) wide and above that, two casement windows measuring 1 x 1m (3.3 x 3.3 ft) each.
By chance, I just noticed that the fixed glazing seems to be leaking, and as if that weren’t odd enough, it is at a very unusual spot.
The lower frame consists of two parts, so there is a "plastic joint," a seam or connection between these two parts.
And moisture is coming from there, with some brownish discoloration visible as well.
I’ve attached a photo.
Now, the actual question:
How can this happen?
It’s currently dark outside and raining, so I can’t check whether there are drainage caps or similar. But that’s unlikely on fixed glazing, right?
I hope you have a good tip for me.
It seems that hardly anything underneath the laminate flooring has become damp, but of course, I want to fix the cause as quickly as possible...
Enrico
Close-up of a white shelf with scratches; underneath lies a colorful newspaper.
profil65
11 Jan 2023 21:20
Please provide one photo each from the outside and inside showing the entire window along with the adjacent wall/reveal, lintel, and windowsill.
parcus
11 Jan 2023 21:50
As long as the drainage on the OUTSIDE of the frame profile is not sealed, no water can come through the glazing bead joint.
B.Baumeister
12 Jan 2023 06:07
Photos will follow, but I can only manage that by Friday afternoon.
By the way, the humidity level is 29%.
parcus
12 Jan 2023 09:41
29% and no health issues so far
Sorry, but I have never seen such a reading with moisture problems and the current weather.
I'm out of here,...
Müller SV12 Jan 2023 14:08
Hello, just a quick note to the group.
Regarding the water drainage, it is probably related to the rebate drainage, especially since the pictures are not very clear.
What can be seen is a triple-glazed insulating glass unit with a black spacer edge.
A glazing bead with an injected EPDM seal.
It would be helpful to know which profile system is being used so we can go into more detail.
So, are the setting blocks properly installed, are enough drainage channels milled in, and are ventilation grooves milled at the top of the outer frame? (For windows with RAL 7016, this is specified in the installation guidelines.) There are many potential points of failure, so GOOD PICTURES are important.
Thorben Müller
B.Baumeister
13 Jan 2023 15:39
parcus schrieb:
29% and still no health issues
Sorry, but I have never seen a measurement like that with moisture problems and the current weather.
I’m out of here,...
The arrogance and tone some people use here is truly unbelievable.
Who do you think you are?!
