I once came across a solution where a heat exchanger is installed in the chimney or its hot exhaust gas flow, which is then used to transfer additional heat to the heating system for support.
Now my question is: What happens if the power goes out and the pump cannot operate? Would I then be unable to use the chimney as well?
Lexmaul79 schrieb:
Forget about that with a heat pump – it only leads to problems and frequent cycling. With gas, it works... I would rather go for a water-based fireplace in that case.What exactly for problems?
Sebastian7927 Aug 2015 12:47You need a buffer tank, which a heat pump generally struggles with – it usually starts short cycling and reacts sensitively to stratified layers in the tank.
The efficiency and therefore the annual performance factor decrease, and essentially, you’re only causing additional costs.
In short...
In short...
Sebastian79 schrieb:
You need a buffer tank, which a heat pump generally struggles with – it usually starts short cycling and reacts sensitively to stratification in the tank.
The efficiency and thus the annual performance factor decrease, and basically, this only leads to higher costs.
In short...Hello
Could you please explain that in more detail?
Olli
Sebastian7930 Aug 2015 19:59You need to set a higher flow temperature to charge the buffer tank. This causes the heat pump to cycle frequently to fill the excess storage. The buffer tank also has heat losses and is quite expensive.
There was also a study by the Fraunhofer Institute that clearly demonstrated the efficiency decreases when using a buffer.
