ᐅ Flue Control / Pressure Switch for Shutoff of Mechanical Ventilation with Heat Recovery
Created on: 25 Mar 2019 20:57
Mottenhausen
Hello everyone!
For the approval of the wood stove when a controlled residential ventilation system is present, a suitable regulation or shutdown of the ventilation system is necessary to prevent smoke gases from being drawn into the living space. Can anyone advise me on exactly what is required? Any recommendations? Certifications?
Situation:
- Controlled residential ventilation system by Viessmann
- Wood stove (not open combustion) with its own (room-air independent) fresh air supply from a duct in the chimney
During the electrical planning, the electrician was unsure about the requirements and recommended a stove control system from Brunner including installation for €1250. However, I believe there is a misunderstanding. My concern is not to electronically control the wood stove (automatic damper) but simply to implement a shutdown of the controlled residential ventilation (switched outlet), that is, temperature- or pressure-controlled during the operation of the stove while the stove door is briefly opened for refueling and potential negative pressure occurs.
A preliminary meeting with the responsible chimney sweep will take place soon, but I would like to be informed beforehand. The electrician honestly admitted that he is not very familiar with this and would install something else that the chimney sweep might accept. Even if he cannot get it from wholesale, we are welcome to order it, for example, online.
Mottenhausen
28 Mar 2019 08:59
Our chimney sweep is expected to be quite strict; others in the neighborhood have already had mixed experiences.
Since the wood stove hasn’t been finalized yet but will likely be from the "DIY store" range for cost reasons, we will almost certainly need a differential pressure monitor. The specific stove will, of course, be chosen in consultation with the chimney sweep—I have already printed out various datasheets and certifications from manufacturers.
The price limit for the stove is €3000, which unfortunately doesn’t get you very far when buying from a stove specialist.
However, even with the differential pressure monitor, this option is still more affordable.
andimann28 Mar 2019 10:29
Mottenhausen schrieb:
The budget limit for the stove is 3000€, which unfortunately doesn’t get you very far with a stove builder.
Well, you can get quite a bit with 3000 euros (approximately 3200 USD), it’s no longer entry-level from a hardware store. We have a Skantherm Emotion M. We paid just over 3000 € (about 3200 USD) for the DIBt-certified version. In spring, there are often special offers and 10% discounts from stove builders.
Andreas
28 Mar 2019 18:03
The Olsberg Palena Compact is available with certification for under 3000€
fach1werk
28 Mar 2019 19:28
And chimney sweeps no longer have compulsory customers... You can also hire someone other than the official one. I went through this two years ago in Baden-Württemberg for a family member with an old existing wood stove with glass doors. One wanted it dismantled, the other classified it as an open fireplace and therefore allowed. Since then, he has also been handling the somewhat more profitable tasks like the energy performance certificate for me.
Gabriele
fragg
1 Apr 2019 09:31
Our chimney sweep is supposed to be quite strict; others in the neighborhood have also had mixed experiences.
Since the wood-burning stove hasn’t been finally chosen yet, but for cost reasons it will probably be one from a DIY store, we will definitely need a pressure monitor. The final stove selection will, of course, be coordinated with the chimney sweep—I’ve already printed out various datasheets and certifications from manufacturers.
The price limit for the stove is 3000€ (about $3300), which unfortunately doesn’t get you very far with a professional stove builder.
Still, even with the pressure monitor, this option is cheaper for me.
Justus Reno R. Justus is the DIY store series from Oranjer, and the certified RLU stove Reno R costs roughly around a thousand. At toom, there are occasionally promotions like a €25 ($28) voucher per €100 ($110) spent and free trailer rental for 5 hours if you spend €250 ($275) or more. They load it onto the trailer with a forklift. The stones around the edge and the top can be unscrewed, so it then only weighs about 100–120 kg (220–265 lbs), making it easy to unload and move by yourself. Otherwise, you can simply filter on sites like Feuerdepot or similar online shops for DIBt-certified or RLU stoves and see what’s available.
fach1werk schrieb:
And chimney sweeps no longer have captive customers... You can also hire a different one than the strict one. I went through this process two years ago in Baden-Württemberg for a family member with an old existing wood stove with glass doors. One wanted it dismantled, the other classified it as an open fireplace and therefore allowed. Since then, this sweep also takes care of the more lucrative things like energy certificates.
Gabriele
The initial commissioning must be done by the local chimney sweep.
