ᐅ Prefabricated Solid House vs. Traditional Masonry Construction
Created on: 21 Oct 2024 15:17
skyliner905
we are planning to build a house in the near future and are currently looking into different construction methods. Unfortunately, I haven’t been able to find clear information about the advantages and disadvantages of prefab solid houses (for example, with lightweight expanded clay concrete prefab walls) compared to traditional masonry buildings.
Do you know of any resources that objectively compare both methods? Construction companies usually praise their own building techniques. Are there any disadvantages regarding the long-term value retention of prefab solid houses compared to masonry, similar to those sometimes associated with timber frame construction?
Do banks really no longer make distinctions in their evaluations? However, I suspect that, for example, fire insurance for a timber-framed house might be more expensive, right? I would expect better sound insulation with masonry at least, although I’m not certain. Due to the greater mass, it should also stay cooler longer in summer, shouldn’t it? Are these just outdated prejudices or reality? I would expect more precision in measurements with timber construction?! Generally, it has been a long-standing debate for years.
nordanney7 Apr 2025 20:51derdom schrieb:
Do banks really no longer differentiate in their valuations? No. Modern houses are all valued the same (I work at a bank).
derdom schrieb:
I suspect, for example, that fire insurance would be more expensive for a wooden house, right? The odds were 50:50. Unfortunately, you guessed wrong. Even here, there are practically no differences.
derdom schrieb:
I would expect better sound insulation from masonry, at least, without knowing for sure. Wrong again, as usual.
derdom schrieb:
With the higher mass, it should stay cooler longer in the summer, right? Depends on the insulation. Solid construction has a slight advantage here. Or disadvantages too, because once the heat is inside, it’s harder to get it out.
derdom schrieb:
All outdated prejudices or reality? Here’s a concise answer: Yes
@nordanney thank you for your summary. However, when it comes to impact sound insulation of a wooden ceiling compared to a solid concrete ceiling, I would definitely see the advantage with concrete. Maybe we visited the wrong prefabricated houses, but I found it quite clear.
