ᐅ Prefabricated Solid House vs. Traditional Masonry Construction
Created on: 21 Oct 2024 15:17
skyliner905S
skyliner90521 Oct 2024 15:17Hello everyone,
we are planning to build a house in the near future and are currently looking into different construction methods. Unfortunately, I haven’t been able to find clear information about the advantages and disadvantages of prefab solid houses (for example, with lightweight expanded clay concrete prefab walls) compared to traditional masonry buildings.
Do you know of any resources that objectively compare both methods? Construction companies usually praise their own building techniques. Are there any disadvantages regarding the long-term value retention of prefab solid houses compared to masonry, similar to those sometimes associated with timber frame construction?
nordanney21 Oct 2024 15:22skyliner905 schrieb:
Unfortunately, I can’t really find much information about the advantages and disadvantages of prefabricated solid construction houses (e.g., with lightweight expanded clay concrete prefabricated walls) compared to traditional masonry houses.That’s probably because there aren’t any significant advantages or disadvantages. It’s just a different construction method. You also have to differentiate between each material type—for example, precast concrete walls require very detailed planning in advance, since you can’t easily install or modify any wiring later (cutting into concrete walls is no fun). Prefabricated walls are assembled faster but require preparation time at the factory. Traditional masonry allows for more spontaneous changes on site, and so on.N
nordanney21 Oct 2024 15:23skyliner905 schrieb:
Are there any disadvantages in value retention for prefabricated solid houses compared to traditional masonry, similar to houses built with timber frame construction?All construction methods nowadays are considered equivalent. There are no different assessments regarding value retention or lifespan. It’s just a different building technique, with quality being the same across the board.If you find a contractor you’re still satisfied with at the end of the construction period, the building method used is practically irrelevant, unless you have very specific requirements that can only be met by a particular construction technique.
It’s more important to carefully consider your floor plan and the individual needs you have for your home.
Advantages and disadvantages of prefabricated solid houses (e.g., with lightweight expanded clay concrete (LECA) precast walls) compared to traditional masonry houses. Our first house had LECA precast walls and had to be fully planned well in advance; we moved in one year after finalizing the planning.
Our second house was built with LECA blocks and a small general contractor, which allowed much more flexibility for us. We moved in six months after finalizing the planning, with the last major change discussed at the topping-out ceremony.
Both houses are comfortable to live in.
Are there any disadvantages in the value retention of prefabricated solid houses compared to traditional masonry, similar to houses with timber frame construction?In reality, never, and nowadays not even in the minds of local bank lenders. The quality varies among manufacturers from A to Z, but you can’t tell from the material whether it’s factory-made or built on site. skyliner905 schrieb:
Do you know any websites or resources where both methods are compared objectively? Construction companies always praise their own building method.No. I am an independent building consultant with over forty years of experience. Still, I don’t have a one-size-fits-all answer (because there isn’t one). For my clients, I find out individually—which only works case by case—by sending a preliminary design to typically three masonry and three timber companies during the decision phase (see external: "A house building roadmap, also for you: the phase model of the HOAI!") to find out. Then the architect can proceed more precisely with the planning. Each case has its own “indications” for when one building method might be more suitable than another, which can also vary depending on the plot of land. Roughly speaking, with the same specifications, a house will cost roughly the same regardless of the building method. “Prefabricated” does not necessarily mean faster, “solid” does not necessarily mean more robust. skyliner905 schrieb:
We want to build a house in the near future and are currently looking at different construction methods. Unfortunately, I can’t find much information on the pros and cons of prefabricated solid houses (e.g., with clay block precast walls) compared to traditional masonry houses.Arauki11 schrieb:
Focus more on your floor plan and your individual requirements for your house.You are probably still very new to this topic and the forum. The question of construction method is pretty much putting the cart before the horse, both generally and in detail (see forum search for the keyword “11ant Steinemantra,” where you’ll also learn that this applies, in principle, to “heating systems” and more).At the core, it’s about you and your requirements profile. Do you already have a plot of land?
