Stein20236 Mar 2023 23:43Hello everyone,
Is there a current guideline for how high the finished floor should be above street level? Or what are your experiences—how many steps do you have leading up to your front door?
Thank you very much
Thank you very much
WilderSueden7 Mar 2023 08:42We are just slightly below. No steps to the front door are planned, only a small ramp. This, of course, requires that we go deeper at certain points and can direct water around the house.
hanghaus20237 Mar 2023 09:40What does the development plan say about that?
Show us the house drawn onto the plot with elevation details.
We can’t give you any advice without that.
For example, I have three steps up. How does that help you?
In our case, the architect originally planned for 15cm (6 inches) above the curb, which is then adjusted for slope during paving without a step. The distance to the property line is about 6–7m (20–23 feet). A wise saying is, “You should look up to the house, not down at it.” In some building areas, this was not considered, and you can see the truth in this statement.
WilderSueden7 Mar 2023 09:54When it comes to height, also consider the sewage system if necessary. With a slab foundation, this is usually not an issue, but with a basement, a lifting station may be required.
