ᐅ Final stage floor plan: Is there still potential for improvement?
Created on: 16 Apr 2018 22:14
modder
Plot size: 606m² (6519 sq ft)
Slope: slight north-facing slope (3m (10 ft) over 34m (112 ft) length)
House: south-north = 1m (3 ft) height difference
Site occupancy index: 0.35 (212m² (2282 sq ft))
Floor area ratio: 0.40 (242m² (2605 sq ft))
Building envelope: marked in blue (approx. 11.8 x 14.5m (39 x 48 ft))
Boundary construction allowed: no
Parking spaces: 2
Number of floors: two full stories: ground floor + upper floor
Roof type: 38–42° (degrees) gable roof
Architectural style: traditional
Ridge orientation: south-north
Maximum heights / limits: northern eave-side wall height above natural ground level: 3.80m (12 ft 6 in)
Additional requirements: knee wall height from top of raw floor slab to bottom of wall plate 0.50m (70cm / 1 ft 8 in approx. inside)
Style, roof shape, building type: all according to development plan
Basement, floors: basement + ground floor + upper floor
Number of occupants, ages: 28 (female), 30 (male), plus at least 1 planned child
Space needs in basement: hobby room, utility room, pantry/storage, sauna planned later
Space needs on ground floor: living room, dining + kitchen, WC, hallway
Space needs on upper floor: master bedroom, dressing room, child 1 + child 2, hallway, bathroom
Office: home office!
Overnight guests per year: 3 guests at Easter and Christmas
Closed architecture
Conservative construction style
Open kitchen connected to dining room
Number of dining seats: 5
Living room fireplace: wall-mounted ethanol fireplace
Music / stereo wall: yes
Garage or carport: single or double garage
Other: hallway large enough to bring in and temporarily park a stroller, e.g., when it’s raining outside; staircase with 1m (3 ft 3 in) wide steps and easy to walk on (hence double landings); living room at least 4.5m (15 ft) wide; no direct connection between parents’ and children’s bedrooms; stairway not located in entryway dirt area; all interior doors with 985mm (39 in) clear opening; dining room: lift-and-slide door with 3m (10 ft) width
- Designer: do-it-yourself
- What do you particularly like about it? Why?
Double-landing staircase, kitchen and dining area facing south, circulation area on the north-east side; large glass window in dining room facing garden, G-shaped kitchen, enlargement of children’s rooms with dormer windows; hallway hopefully spacious-looking even though it could be a little wider
- What do you dislike? Why?
No room for a urinal in the ground floor bathroom
Basement not yet well planned, unsure how to properly separate a future sauna room
Personal budget limit for house including equipment: €425,000
- Preferred heating technology: air-to-water heat pump / ground loop collector + mechanical ventilation with heat recovery + underfloor heating
If You Have to Give Up Anything, on which details / features
- Could give up: exposed roof structure
- Cannot give up: shower in ground floor WC; staircase with straight steps; stairway outside the dirt zone; wardrobe
Why is the Design Like It Is?
Lots of reading layout reviews here, input from builder friends; about 100 hours of drawing floor plans
- What makes it especially good or bad in your view?
In our opinion, very efficient use of space in a relatively small house, pleasant hallway layout
What Is the Most Important / Basic Question About the Floor Plan Summarized in 130 Characters?
Is this floor plan practical?
Are there any major issues or deal-breakers we might have overlooked?
Attached are our own drawings from SketchUp / site plan from the development plan
Our plot is number [9]
Note: Unfortunately, windows are missing on the upper floor. There are planned windows on the gable ends sized 150 x 138cm (59 x 54 in), dormer windows each approx. 200 x 138cm (79 x 54 in), and in the stairwell, master bedroom, and bathroom an additional double casement window sized 78 x 160cm (31 x 63 in)
Parking spaces: 2
Closed architecture
You can achieve this better with a wall of plants. You can also remove it easily if you want to rearrange the furniture. These small privacy screens really only make sense for the toilet area (and even then, they’re not absolutely necessary). Otherwise, it’s better to work with plants and/or furniture (a sideboard would have the same effect).
The distance between the kitchen island and the kitchen unit at 130cm (51 inches) is too large. You will always have to take an extra step when placing something from the unit onto the island or vice versa. Definitely reduce this distance!
I find the slant near the dining table unclear (and unattractive); I would make it straight. It would probably increase the price compared to the classic corner design.
Uhh, is 1.30m (4 ft 3 in) too large? I always read "at least" 1.20m (4 ft) everywhere. Since there is enough space, I planned for 1.30m (4 ft 3 in). How wide would you make it?
The angled shape at the dining table is there because it makes the room feel a bit smaller (there is still 3m (10 ft) between the kitchen island and the dining table). We also thought this way the sun would come into the room better, especially in autumn and winter. The terrace will also be larger on the "chocolate side." Regarding the cost of the corner, we should discuss that with the carpentry team, but they will probably say the same as you.
We will probably do the plants instead of small walls as well. That’s how it currently is in our apartment, too. A 6m (20 ft) wide living room, and next to the sofa there is the speaker, a spiky palm, and a support column for the ceiling.
The ideal distance between two work surfaces is 110 - 120cm (43 - 47 inches), unless both of you are very tall with long legs and arms.
The "classic" workflow is usually taking something from one surface and placing it on the other. Try this with a table and an ironing board. The ideal distance is when you only need to turn your body slightly to move something from one surface to the other. No stepping in between.
I find this "just have to turn" idea a bit overrated. We have about 120 cm (48 inches), maybe a little more (I would need to measure again), and I think the space between the two rows is good. Two people can work together and even leave a drawer open without getting completely in each other's way.
I find it more comfortable to take a step out of the rotation. Without this step, the space can feel cramped, especially when a drawer is open and/or people need to pass each other. We have a distance of 1.28 m (4 feet 2 inches), which I find rather tight than spacious. We are 1.75 m (5 feet 9 inches) and 1.83 m (6 feet) tall, so not short, but not very tall either.
