JayneCobb15 Oct 2023 16:08Hello everyone,
we are currently building a single-family house.
The one-time exterior painting is included in our contract and was completed last Friday. The plasterer offered us a second coat.
The only advantage, as we understand it, is that we would not need to repaint after 5 to 7 years, but later on.
The paint used is a Caparol silicone resin-based paint (white with a slight gray trim as a visual separation at the garage), and the cost is about 2500 euros net.
What has been your experience? Is it worth it?
Thanks in advance!
Thanks in advance!
JayneCobb16 Oct 2023 02:34Addition: The plaster is a two-layer mineral scratch coat, approximately 20 mm thick (base coat and finish coat).
WilderSueden16 Oct 2023 08:41We had the exterior painted twice. I’m not very motivated to renovate a deteriorated facade after 5 years.
KarstenausNRW16 Oct 2023 08:53Applying two coats of paint makes sense.
However, I don’t understand why someone would paint a mineral-based plaster with such a crappy silicone resin paint. It just doesn’t make sense to me...
Pinkiponk16 Oct 2023 09:21This was neither offered nor discussed with us (prefabricated house using a timber frame construction). I don't even know how often it was painted. I probably should have looked into that.
JayneCobb16 Oct 2023 19:00Thank you all!
We have now decided on that.
What exactly would be the problem with that?
A brief explanation would be helpful for non-experts…
In any case, I discussed this with the plasterer.
He said the paint is well suited for mineral plaster. It only contains 4-5% silicone, but that’s why it has to be called silicone resin paint.
KarstenausNRW schrieb:
Applying two coats makes sense.
However, I don't understand why someone would paint such silicone resin paint over a mineral-based plaster. It just doesn't make sense to me...
