ᐅ Exterior Walls – Brick or Timber Frame Construction?
Created on: 13 Dec 2021 17:25
MichaelÖ64
MichaelÖ64
13 Dec 2021 17:25
In my contract with the construction company, I agreed to use the brick "Wienerberger 50-20 Plan" for the exterior walls of the house.
Now, the construction company has sent me the submission documents, but instead, the specification for the exterior walls states: "25cm (10 inches) timber frame masonry + ETICS (20cm (8 inches) EPS F-Plus + silicate plaster)," so apparently only 25cm (10 inches) brick plus insulation.
The construction company explains this as follows:
"For the exterior wall, a thickness of 25cm (10 inches) brick plus 20cm (8 inches) insulation was chosen due to better properties.
The U-value of a 50cm (20 inches) brick wall is 0.156 W/m²·K, and for a 25cm (10 inches) brick plus 20cm (8 inches) insulation wall it is 0.138 W/m²·K.
With a 25+20 exterior wall, sealing is much better, there are fewer thermal bridges, and there are no problems with installing roller shutters."
I am now uncertain – should I insist on the original version or choose the new one?
Additional info: The house is single-story, just under 8 meters (26 feet) high, and since it will mostly be used in summer, it is more important to me that it does not heat up quickly and strongly, rather than cooling down fast. Sound insulation is less important, as the neighbors are far away.
Thanks in advance for your answers!
andimann13 Dec 2021 17:30
even if I completely confuse you with this: then you are mistaken with the Wienerberger Porcelain. Mass is what helps you. Calcium silicate walls, preferably 24cm (9.5 inches), and then 20cm (8 inches) insulation. That’s the finished cabin.
Andreas
11ant13 Dec 2021 18:44
MichaelÖ64 schrieb:
Now the construction company has sent me the submission documents, and in the building description, under exterior walls, it says: "25cm timber frame masonry + ETICS (20 cm EPS F-Plus + silicate plaster)," so obviously only 25cm (10 inches) brick plus insulation.
What on earth is a TIMBER frame MASONRY supposed to be?
TmMike_2
13 Dec 2021 19:05
I would also recommend 24cm (10 inches) sand-lime bricks with a density of 2.0. I have 17.5cm (7 inches), and yes, then you have a very solid structure that’s hard to find otherwise. It should hardly affect the cost.
