ᐅ Exterior walls made of 24 cm hollow clay bricks: should I use external thermal insulation composite systems (ETICS) or Poroton T7 blocks?
Created on: 31 Oct 2020 11:27
sascha-t4-le
sascha-t4-le
31 Oct 2020 11:27
I am at the beginning of the planning phase and considering whether to build the exterior wall with hollow bricks or Poroton blocks. At this point, I would be interested to know what you have chosen and what your reasons were.
Thank you for your input.
sascha-t4-le
Bookstar
31 Oct 2020 12:09
Use filled Poroton blocks, and everything will be fine.
nordanney
31 Oct 2020 13:38
It doesn’t matter. Both have their own justification.
sascha-t4-le
31 Oct 2020 13:44
I am not saying that one of them would be unnecessary. I also know that in the end everything will be fine and all tears will be dried.
My question is directed at homeowners who faced the same choice and why they decided on a particular type of masonry?
nordanney
31 Oct 2020 14:00
Sand-lime bricks because I like them and prefer truly solid construction. So, what now?
Bookstar
31 Oct 2020 16:51
Unfilled is useless because of sound insulation. External thermal insulation composite system (ETICS) is used for plaster and installation.
That’s why filled brick. The best of all.
