ᐅ Exterior Wall Bricks: Should You Choose Hollow, Solid, or Facing Bricks?
Created on: 4 Aug 2018 11:01
U
ufr123
I have gone through countless discussions about bricks by now. However, some questions remain regarding the construction of our single-family house.
In the meantime, we have decided on bricks without external thermal insulation composite systems (ETICS).
What remains unclear is whether to use filled (perlite), unfilled, or possibly even a (more stable) engineering brick from the ranges offered by well-known manufacturers.
It is important to us that the brick is not too crumbly and that kitchen cabinets, etc., can be securely fastened with reasonable effort. Sound insulation is also a factor.
How do you see the following points:
  • Which type of brick is more "stable," or which holds fixings better?
  • Are bricks with lambda values of 0.09 to 0.12 in practice significantly more stable than those with 0.07–0.08?
  • Are unfilled bricks more crumbly than filled bricks?
  • Is the extra cost for engineering bricks designed for multi-family buildings worth it for sound insulation and stability reasons?
  • Do sound insulation ratings of bricks above 45 dB make sense at all if no soundproof windows are installed (since the "weakest link" for sound would then be the windows)?
  • How do filled bricks compare to unfilled bricks in terms of price, i.e., which is more expensive? (As a layperson, I found the price lists from well-known manufacturers quite contradictory)
Thanks for your input
ufr123
11ant4 Aug 2018 18:31
Alex85 schrieb:
The statement is correct that filled bricks tend to have thicker walls
If they have a different chamber profile, yes.
hanse987
4 Aug 2018 18:51
Just a quick note about hollow bricks. When drilling for anchors, always turn off the hammer function on the drill to avoid damaging the internal webs. It takes more effort to drill this way, but the anchor will hold better.
bon19804 Aug 2018 23:41
This applies equally to bricks with filling.
