ᐅ Extending Billy Regal Shelves – How Can I Do That?
Created on: 4 Jul 2021 08:37
niall-neo
I want to extend the shelves of my Billy bookcase to accommodate wider items. My goal is to increase the shelf depth without having to buy a completely new bookcase. My question is: What options are there to independently extend existing Billy shelves while maintaining load-bearing capacity and ensuring the stability of the bookcase is not compromised? I am also considering suitable materials and fastening methods to ensure a secure hold.
I look forward to constructive tips and experiences, including advice on mistakes I should avoid.
ritotar
5 Jul 2021 08:58
Hey!
I really like how this topic is being discussed here! 🙂
A tip from me: If you extend the shelves, try using a thin plywood panel instead of just wooden slats. It’s very sturdy and can be cut thinner, so the look won’t be too bulky.
niall-neo schrieb:
Should I use metal brackets for this or would a wooden construction also work?
Metal brackets are more stable but often less visually appealing. A well-screwed wooden frame under the shelf looks more natural and provides excellent support, especially if you paint or finish the extension afterward.
A small assembly tip: use glue along with countersunk screws so they don’t stick out bulky later. And don’t forget to pre-drill!
laureo
5 Jul 2021 12:44
For the stability of extended shelves, the following points are important:
The load capacity of a shelf mainly depends on the support width and the material used. When shelves are extended, the bending moment increases, which raises the risk of sagging.
Therefore, I recommend:
- Using wood with high bending strength, such as plywood or beech.
- Installing additional cross beams underneath the extension that engage with the shelf frame.
- Using wood screws of suitable length (at least 4 cm (1.5 inches)), pre-drilled to prevent splitting.
If the appearance allows, attaching quality metal brackets is a proven method and significantly improves the structural strength.
If anyone needs more detailed information, I am happy to provide construction sketches.
neoren
6 Jul 2021 10:05
I would like to add: When extending shelves, always secure the shelf to the wall and avoid distributing the load unevenly. This helps prevent the shelf from tipping over or the floor from sagging excessively.
