ᐅ Extending Billy Regal Shelves – How Can I Do That?
Created on: 4 Jul 2021 08:37
niall-neo
niall-neo
4 Jul 2021 08:37
I want to extend the shelves of my Billy bookcase to accommodate wider items. My goal is to increase the shelf depth without having to buy a completely new bookcase. My question is: What options are there to independently extend existing Billy shelves while maintaining load-bearing capacity and ensuring the stability of the bookcase is not compromised? I am also considering suitable materials and fastening methods to ensure a secure hold.
I look forward to constructive tips and experiences, including advice on mistakes I should avoid.
neoren
4 Jul 2021 09:02
a simple method is to cut wooden strips to the required depth and screw them underneath the existing floors. It is important that the screws hold firmly and that the board remains stable. Alternatively, you can buy wider boards and simply replace the old ones.
LOGEMIN
4 Jul 2021 09:47
Here is a brief overview of how to extend Billy shelf boards without compromising stability:
1. Material selection: The extension should be made from wood that matches as closely as possible to maintain appearance and strength. MDF or solid pine are often suitable, with the latter usually offering better load-bearing capacity.
2. Preparation: Measure the shelf boards and cut the extension board precisely so that it fits flush.
3. Connection: The most common method is gluing and screwing. Use wood glue plus small screws or wood connectors on the underside to keep the joint stable yet invisible.
4. Stabilization: It is helpful to mount an additional sturdy support beam under the extended board, attached to the inside of the shelf. This will carry the extra weight.
5. Surface treatment: Paint or stain ensures a clean look and protects against moisture.
Typical mistakes include inaccurate measurements or neglecting load capacity – otherwise, the shelf can sag. If the extension is expected to carry significantly heavier loads, it is generally advisable to consider a new shelving structure.
I hope this is helpful.
kemeo68
4 Jul 2021 11:13
Interesting question.
I am always amazed at how many people modify Billy shelves as if they were high-tech products. Why not just buy something more sturdy right away? Billy is more of a simple solution.
LOGEMIN schrieb:
If the extension is going to be loaded significantly heavier, a completely new shelving structure should generally be considered.
That’s my point. Extending often only offers cosmetic benefits, while load capacity usually suffers. If you want more, you have to choose other shelving systems. Or you can build something sturdy yourself from the start, which will be more worthwhile for the effort.
LUISABEL
4 Jul 2021 14:56
Regarding the topic of extending Billy shelves and shelf boards, I would like to point out a few facts:
The original Billy shelves are typically 28 cm (11 inches) deep and can carry a maximum load of about 15 kg (33 lbs) evenly distributed. When the shelves are extended—especially significantly—the load distribution changes, and stability decreases.
If you are extending the shelves, you should definitely:
- Reinforce the joint between the original and the new wood with appropriate connectors and glue
- Add an additional support strip or a side panel underneath for support
- Use the same material whenever possible, as different types of wood and thicknesses can cause warping
Even if it seems complicated, you should first check whether the entire bookshelf is suitable for the intended use.
Sometimes an extension in the form of an addition (a new bookshelf next to it) is more practical than extending individual boards.
niall-neo
5 Jul 2021 07:21
kemeo68 schrieb:
Why not just buy something more sturdy right away? Billy is rather a simple solution.
Thanks for the input. I’m not really concerned about maximum loads but rather lowering the height to accommodate wider items. The load remains moderate, but the original depth is simply too shallow for this purpose.
LOGEMIN schrieb:
Mount an additional sturdy strip under the extended board, attached to the inside of the shelf frame.
That sounds like a good idea to me, as it would increase the load-bearing capacity. Should I use metal brackets for this, or would a wooden construction also work? What about fixing it to the shelf frame—are there specific screws or anchors you would recommend?
