ᐅ Extending Roller Shutter Connection Cable
Created on: 16 Jun 2016 12:10
KarlR
KarlR
16 Jun 2016 12:10
Our house is currently in the shell construction phase. The windows have been installed, and the electrician has finished chasing and drilling the walls and is now attaching the flush-mounted boxes.
I noticed that the connection cable for the roller shutter at one window seems to be broken. It is much shorter than the others, and a box was drilled just below the ceiling next to the roller shutter. (This is not the case at the other windows.) It is likely meant to be a flush-mounted box where the cable will be extended.
Now my question:
Do I have a chance to claim this as a defect with the builder?
I don’t want a box next to the window (because of the curtain rod), and besides that, every additional connection point is another potential source of failure.
After all, I am paying for an intact motor with a complete cable.
Ideally, I would prefer a replacement of the motor and thus a new connection cable that runs directly to the switch next to the window.
What do you think?
nordanney
16 Jun 2016 13:05
I personally wouldn’t care about that at all. A defect? You ordered a functioning roller shutter motor and that’s exactly what you’re getting (layman’s opinion).
Mycraft16 Jun 2016 13:29
No defects present. A connection using flush-mounted boxes at the control panel is actually more advantageous.
For example, this allows for a much quicker replacement of a faulty motor...
I would even recommend the opposite approach (and did so in my case), meaning a flush-mounted box for each motor and sometimes even one on the left and right side. This makes many things much easier later on.
K1300S16 Jun 2016 18:20
One more point: you can't drill there without a mounting box either. And from my experience, using a flush-mounted box is rather the standard practice than the exception.
KarlR
16 Jun 2016 18:55
Why am I not allowed to drill there? I would keep a safe distance from the cables.
MarcWen16 Jun 2016 19:29
Then keep enough distance from the junction box and remember the position well.
