ᐅ Experiences with window profiles such as Kömmerling, Schüco, and others
Created on: 14 Dec 2022 18:51
dr30000Hello,
I am currently planning to build a new house and have received several quotes for windows. Below, I have selected balcony sliding doors sized 240/220 cm (94/87 inches) as an example.
1)
PROFILE: SCHUCO LIVING 82 AS
COLOR: ANTHRACITE
GLAZING: ISO 4+12+4+12+4 Low-E
HARDWARE: Roto fittings, burglar resistant, locking points at 6-8 locations depending on window size, CLASS 1
BLINDS: TOP THERMO PLUS two-part with central guide
2)
PROFILE: Kömmerling Profine 88MD
COLOR: ANTHRACITE / ULTIMATE WHITE
GLAZING: IZO LOW-E 1.1 4+16+4 FLOAT+16+4 FLOAT (44 mm (1.7 inches))
HARDWARE: Maco SKB-S hardware for sliding rods [SMEDA F5]
BLINDS: Two-part VariNova blinds [2p2a] - A - Anthracite
SLATS: Aluminum slats in Anthracite
MOSQUITO NET: Yes
3)
PROFILE: Gealan 9000
COLOR: WHITE DECO
GLAZING: 4 Low-E - 12 - 4 Float - 12 - 4 Low-E + Argon
HARDWARE: MACO MULTI MATIC tilt-and-slide [brown]
BLINDS: Two-part blinds 2P2G - WHITE DECO
LAMPS: Aluminum slat blinds 37 mm (1.5 inches) - decorative
4)
PROFILE: Kömmerling 76MD
COLOR: ANTHRACITE OUTSIDE WHITE INSIDE - ONE SIDE
GLAZING: 4 Low-E - 16 - 4 Float - 16 - 4 Low-E + Argon
BLINDS: Two-part blinds VN [2p2a] - A - Anthracite outside white inside - one side
HARDWARE: Winkhaus AktivPilot security fittings with ventilation function
SLATS: Aluminum slats anthracite RAL 7016
MOSQUITO NET: Yes
I am not sure which offer is the best. Basically, I tend to reject Kömmerling, but I am not an expert. Also, I would be interested to know if there is a significant difference between the 76MD and 88MD profiles.
I would appreciate any experiences with the window profiles listed above or general recommendations.
Thank you in advance!
1)
COLOR: ANTHRACITE
2)
MOSQUITO NET: Yes
3)
COLOR: WHITE DECO
4)
MOSQUITO NET: Yes
dr30000 schrieb:
I would also be interested to know if there is a significant difference between the profiles for 76MD and 88MD. A 12 mm (0.47 inch) difference already suggests a considerably different construction, don’t you think? Unfortunately, the manufacturer is not very keen on making their product range transparently comparable :-(
