ᐅ Experiences with scuff marks on the KALLAX unit after moving the furniture?
Created on: 21 Feb 2022 08:47
henry46
I recently moved my KALLAX shelf unit from IKEA several times and noticed that there are unpleasant and sometimes quite noticeable scuff marks and abrasions on the edges and surfaces of the carcass after moving the furniture. I’m curious if anyone else has had similar experiences: Have you noticed scuff marks or wear spots on the KALLAX carcass when the piece was moved or rearranged? What do you think causes this, and are there effective ways to prevent these marks or at least repair the damage? I would appreciate any tips on prevention and care for the carcass. I mainly use the shelf in the living room, and the moving usually happens on laminate flooring. Thank you in advance!
Sinan-meo
21 Feb 2022 17:36
Another tip: Before moving the piece of furniture, lift it slightly instead of sliding it, as mentioned earlier. This helps prevent the surface from being permanently scratched in one spot.
Additionally, existing damage can be carefully repaired using fine sandpaper followed by appropriate furniture wax or lacquer. Proceed with caution, as the coating is thin.
Another idea is to place a thin rubber or plastic mat under the shelf if it is moved frequently. This distributes the wear area over a larger surface and makes the scuff marks less noticeable.
laureo
22 Feb 2022 07:55
In the professional sector, special casters are often used for such furniture to make moving easier and to prevent damage. However, for the KALLAX, this involves additional effort and modifications to the construction, which can be challenging for a plug-in shelving unit.
I have often noticed in these cases that the initial setup usually causes fewer problems, but repeated moving without protective pads quickly leads to wear. Therefore, the recommendation remains: felt-backed glides or furniture casters with soft wheels.
henry46 schrieb:
What do you see as the causes for this, and are there effective methods to prevent these spots or at least repair the damage?
You already summarized the causes well: rough flooring, foreign objects, material surface, and mechanical overloading. Regarding repairs: specialized wood repair wax or furniture touch-up markers have proven effective.
letar
22 Feb 2022 09:18
As an addition: You can also use castors from furniture or industrial supplies that come with soft polyurethane wheels. Although they require slightly more effort to install, they provide a more durable and robust solution for frequent moving.
Regularly checking felt pads is also important, as worn pads no longer offer protection. Furthermore, clean floors with as smooth a surface as possible are the best condition for moving furniture.
Aimee
22 Feb 2022 10:46
Glue felt pads, keep the floor clean, and lift furniture instead of dragging it—these are the most important points. For minor damage, use furniture wax to maintain the shelf’s appearance.
henry46
23 Feb 2022 08:22
Thank you all for the helpful answers and tips!
I find the advice about combining felt pads with clean floors particularly sensible. The idea of using soft-tyred casters also sounds interesting—I will give that a try.
I’m still wondering: Are there specific products or kits recommended by IKEA or third-party suppliers as repair materials for the KALLAX? Since the cabinet is made of coated particleboard, I want to avoid anything that might damage or alter the surface.
Maybe someone has experience with such repair kits or can recommend a link here? Thanks!
