ᐅ Experiences with Rimless Toilets
Created on: 10 Feb 2020 17:28
REH63110
REH63110
10 Feb 2020 17:28
For our house project, two different rimless toilets are available:
- Geberit Renova Rimfree
- Clivia Vigour Rimfree
While the Geberit toilet is truly completely rimless, the Vigour has a notch where the water flows along.
I generally prefer the design of the Geberit, but I have been warned from multiple sources that with this type of design, water droplets often splash out, which is quite unpleasant. On the other hand, the Vigour has a kind of rim at the back near the wall, so it is not entirely rimless.
What are your experiences?
Wickie
10 Feb 2020 19:18
We have the Keramag Icon. I think the rim design looks a bit different now. Our toilets have a small "collar" at the back, which seems to be longer in the newer models.
We have had absolutely no problems.
However, I have often heard that splashing is usually caused by too much water pressure. But that can be adjusted. You should look it up online; there are plenty of posts about it!
nordanney
10 Feb 2020 20:04
Wickie schrieb:
We have the Keramag Icon. I believe the flush rim design has changed slightly by now. Our toilets have a small "collar" at the back, which seems to be longer in the newer versions.
We have absolutely no issues.
I also use the Icon without any problems.
