ᐅ Experiences with KALLAX and wet shoes – any damage?
Created on: 15 Jul 2020 08:24
Matida
I am currently wondering how well the IKEA KALLAX shelving unit holds up against moisture, especially from wet shoes. My shoes often end up slightly damp in the compartments, and I’m concerned whether the wood or the surface might get damaged, for example by warping, swelling, or stains.
Does anyone have long-term experience with whether wet shoes negatively affect the stability or material of the KALLAX? And what preventive measures can be taken to avoid damage?
Thank you for your opinions and tips!
fiman
15 Jul 2020 14:13
So, if you don’t want any documentation: place small stones or tiles inside. They prevent moisture from reaching the wood.
Also, don’t leave shoes wet inside for too long.
Roberta
15 Jul 2020 15:01
Placing wet shoes directly on the KALLAX is really not a good idea. The particleboard absorbs moisture and swells. Using a protective base is essential.
Jaime
16 Jul 2020 10:24
In addition to the tips mentioned earlier, I would like to add that stuffing the inside of the shoes with newspaper can help reduce moisture.
Regarding damage: If moisture seeps in and the KALLAX remains damp for an extended period, it can accelerate mold growth, as the particleboard is organic.
Regular ventilation and short drying times are therefore very important.
Basically, I would recommend not using the shelf as a shoe rack for wet shoes, but rather as a dry storage space.
Matida
16 Jul 2020 11:49
TEBILO schrieb:
One more question: How wet are the shoes usually? Just slightly damp after a short rain, or really soaked with mud?
Thanks for the hint, TEBILO. The shoes are usually only slightly damp after a brief shower, rarely really soaked with mud. They typically dry quickly, but I don’t always manage to dry them completely beforehand.
I will definitely try airing them out and using protective mats.
Jaime schrieb:
If moisture penetrates and the KALLAX stays damp for a longer time, this can also lead to accelerated mold growth
That worries me a bit since the shelf is in the hallway, which can sometimes get quite damp. Should I consider using a dehumidifier?
Takutau
16 Jul 2020 12:11
Matida schrieb:
Should I maybe set up a dehumidifier?
A dehumidifier can only help if the indoor air is actually humid. Especially in hallways, the humidity often varies because they connect the outdoor and indoor areas.
First, I would try simple ventilation. If that is not enough, a dehumidifier could be useful.
It is important not to leave damp shoes on the shelf for a long time and to equip the KALLAX with a water-resistant mat. This way, you minimize the risk of damage or mold.
TEBILO
17 Jul 2020 07:03
Absolutely, a dehumidifier can be very helpful, especially in poorly ventilated hallways or if the shelf is placed close to an exterior wall.
You should also check whether the joints and the melamine coating on the KALLAX are still intact – small damages can worsen moisture problems.
Usually, protection through mats and well-drying shoes is sufficient at first. Thanks also for your detailed description; it really makes the assessment much easier.
