ᐅ Experiences with Foam Edge Protectors for Kallax Units
Created on: 17 Oct 2024 08:37
emeka2
emeka2
17 Oct 2024 08:37
I am considering protecting the exposed edges of my Kallax shelving frame with foam. I am especially interested in how well foam works as edge protection for Kallax shelves in daily use.
I want to avoid the edges being too hard, so that, for example, children don’t easily bump into them or items don’t get damaged. It is also important to me how well the foam adheres to the surface, whether it remains stable over time, and if there are specific types of foam that are particularly suitable – such as strips, profiles, or roll material. Are there any issues with installation or cleaning?
If you have experience with the appearance, feel, or durability, I would appreciate detailed information.
Thank you in advance!
tra_nina
17 Oct 2024 10:42
emeka2 schrieb:
How suitable is foam as edge protection for Kallax shelves in everyday use?
Foam as edge protection is generally well suited to prevent injuries and soften edges. It is important to choose a firmer, closed-cell foam (e.g., EVA foam), as this type is more durable and less sensitive to pressure.
emeka2 schrieb:
whether it remains stable over the long term and if there are specific types of foam
In the long term, foam does not always hold up optimally under regular stress and frequent contact, especially with budget options. It is advisable to use extra-strong, self-adhesive edge protection profiles.
For installation: A self-adhesive backing allows for easy, bubble-free application. Cleaning is easy with a damp cloth since closed-cell foam hardly absorbs dirt.
lisku
17 Oct 2024 11:05
The installation is simple: buy self-adhesive foam strips, thoroughly clean all edges, and then stick them on. They usually adhere well but do not last forever. Great for children’s rooms.
fredle
17 Oct 2024 13:27
Basically, I recommend the following procedure for installing foam edge protectors on Kallax:
1. Thoroughly clean and degrease the edge – otherwise, the adhesive will not stick properly.
2. Pay attention to the material thickness. For Kallax edges (4 cm (1.6 inches) deep), foam profiles about 1.5 cm (0.6 inches) thick are suitable.
3. Use only closed-cell foam (EVA or PE), as it is resistant to moisture and pressure.
4. Most foam edge protectors come with a self-adhesive backing; check the position before applying, then press firmly.
Common mistakes include foam that is too thin, unsuitable adhesives, or poorly prepared surfaces. For cleaning afterward, use only a damp cloth; avoid harsh cleaners.
koduga
17 Oct 2024 16:52
tra_nina schrieb:
It is advisable to use extra strong, adhesive edge protection profiles.
I did exactly that because my young son often bumped into the corner, and it really helped. At first, I was unsure about how firm the foam should be. By now, I feel more confident because the shelf seems much safer for children.
You might have to get used to the fact that the appearance suffers a bit, but I’m happy to accept that.
klo61
18 Oct 2024 09:18
Additionally, I have a few tips regarding durability and maintenance:
- Foam can become harder or more brittle over time if exposed to direct sunlight.
- For cleaning, a damp cloth or a little soapy water is sufficient.
- Before installation, it is advisable to test the foam by attaching it to an edge first to check how well the adhesive holds.
- Some users recommend choosing foam strips that are not too thin, especially if children are actively playing with the shelving unit.
Overall, foam is a good solution when it comes to safety, but there is no 100% durability over the years without wear.
