ᐅ Experiences with using films on the surface of older KALLAX units?
Created on: 7 Mar 2022 16:23
Courtney49
Some time ago, I bought an old KALLAX unit with the intention of refurbishing and reusing it. I noticed that the surface laminate sheets are partly damaged or peeling off. I’m curious if anyone has experience with these types of laminates on old KALLAX units—specifically, how durable they tend to be over the years, whether they can be easily replaced, or if there are alternative ways to protect or restore the surface. Perhaps there are different laminate types depending on the production period? Any information or personal experience would be very helpful.
gasidney
7 Mar 2022 19:43
I once completely removed an old KALLAX veneer and coated the wood with clear lacquer. The result was excellent, and the surface has held up reliably for 2 years.
enrique7
8 Mar 2022 10:14
taudi schrieb:
Original films used on KALLAX are usually thermoplastic layers pressed onto the chipboard panels.
Accurate information, thanks. I do wonder, though: Can you really expect good adhesion if the substrate is severely damaged?
Courtney49 schrieb:
Are there also experiences with the difference between films and paint on these wood-based panel surfaces?
In my opinion, paints provide a more durable solution, assuming the surface is prepared correctly. Films offer more visual flexibility if you want to make changes later on.
What about long-term tests? Has anyone examined films after several years of use?
ryan1
9 Mar 2022 08:56
Two years ago, I covered my old KALLAX units with self-adhesive vinyl film – it looks really great and is very practical! 🙂
After two years, there are some slight lifts at the edges, but overall the surface is well protected. For me, it’s a great and cost-effective solution!
If anyone is worried about air bubbles: gently warm the film with a hair dryer, then it can be easily wrapped around the edges and pressed down without bubbles. Don’t get discouraged – it’s definitely worth it!
