ᐅ Experiences with using films on the surface of older KALLAX units?
Created on: 7 Mar 2022 16:23
Courtney49C
Courtney497 Mar 2022 16:23Some time ago, I bought an old KALLAX unit with the intention of refurbishing and reusing it. I noticed that the surface laminate sheets are partly damaged or peeling off. I’m curious if anyone has experience with these types of laminates on old KALLAX units—specifically, how durable they tend to be over the years, whether they can be easily replaced, or if there are alternative ways to protect or restore the surface. Perhaps there are different laminate types depending on the production period? Any information or personal experience would be very helpful.
Courtney49 schrieb:
if there are other options to protect or restore the surface.This is the key issue for me. In my opinion, the films used on KALLAX are not very durable, as they are usually made of thin plastic that eventually cracks or peels off. It would be interesting to know if anyone has found long-term solutions, such as special sealants or coatings that are compatible with the underlying materials. I am skeptical about simple film replacement solutions, especially for older units, since the substrate is often porous or damaged.Hey, about a year ago I refreshed my old KALLAX by simply applying a thin, matte vinyl overlay – it looks great and holds up surprisingly well! 😊 It’s important to work carefully and avoid air bubbles. If the old vinyl starts peeling, just peel it off and replace it; it’s not that much effort. Have fun restoring! 🙂
Courtney497 Mar 2022 18:45todunar schrieb:
Hey, I refreshed my old KALLAX a year ago by simply applying a thin, matte film over it – it looks great and holds surprisingly well!That already sounds very encouraging! Do you remember if the film had any coating (for example, matte or glossy) and how well the edges held up? In my unit, especially the edges showed signs of peeling. Are there also any experiences regarding the difference between films and paint on these wood-based panel surfaces?I can break this down from a technical perspective:
1. The original laminates on KALLAX units are usually thermoplastic layers pressed onto the particleboard. Over the years, the edges experience the most wear and tear, making peeling often unavoidable.
2. For replacement, I recommend sanding the surface as smoothly as possible, then priming it with an acrylic primer. This significantly improves adhesion for films or paints.
3. Both options are viable for protection and appearance—films are cost-effective and removable, while painting offers more durable protection but requires more effort and proper preparation.
4. For a long-lasting finish: water-based polyurethane (PU) varnish protects the surface very well but slightly alters the appearance.
The most important thing: handle the furniture carefully after restoration work.
