ᐅ Experiences with KALLAX replacement parts from China?
Created on: 11 Nov 2024 08:37
Fratan9
Hello everyone! I recently purchased some KALLAX shelves from IKEA and noticed that some replacement parts like screws, dowels, or connector plates were damaged or missing. Since I can no longer buy these original parts, I have been thinking about ordering replacements from China. Before I do that, I would like to hear about your experiences: How is the quality of KALLAX replacement parts from China? Does the workmanship match the original parts exactly, or are there differences in dimensions or materials that one should be aware of? Are the delivered parts durable or more suitable for temporary use? I am especially interested in whether these replacement parts from China can be used reliably over the long term, or if it is better to wait for the original parts even if they are harder to obtain. Also, what are your experiences regarding delivery times and customer service with such orders? Thanks in advance for helpful answers!
Fratan9
13 Nov 2024 08:21
Thank you for your detailed initial responses!
@Filippo: I mainly have shelves fastened with beech wood hinges and screw connections, which were damaged during assembly. The hinges themselves are intact, but the connecting elements like small metal brackets and screws are no longer available.
I’m wondering if there are significant differences in strength between metal brackets, since the shelves do carry some weight. Is there a quality standard to refer to? And would it be advisable to source these exact brackets through official channels while using screws from China?
I’m also interested in practical tips on how to test the durability of the Chinese replacement parts without fully assembling everything right away.
Palenar
13 Nov 2024 11:34
Fratan9 schrieb:
I wonder if there are significant differences in strength among metal brackets, since the floors need to support some weight.
That’s an important point you raise. Metal brackets for furniture are often made from steel with specific alloys and surface treatments. With cheaper parts from China, there is a risk that lower-quality materials are used, such as less alloyed steel or thinner sheet metal, which reduces load-bearing capacity.
The best way to assess this is to check the material thickness and the type of surface coating (e.g., galvanized, painted).
I would recommend the following approach:
1. Specifically look for replacements that provide measurements and material specifications (e.g., “cold rolled steel,” “zinc plated, 2mm thickness”)
2. Test the parts by bending them manually before installation; if they bend easily, they are not strong enough.
3. Screws are usually made from basic types of steel—using a stainless variant is advantageous for durability.
From my own experience: For load-bearing parts like metal brackets, original or high-quality metal parts are advisable. Replacement parts from China are better suited for screws, plastic components, or flat sheets that are not load-bearing.
DUVIN
14 Nov 2024 09:02
If original parts are not available, it is better to use quality products, even from hardware stores, for load-bearing connections. Chinese parts can fail under stress. Screws from China are usually acceptable, but do not take risks with components that are structurally critical.
