ᐅ Experiences with foam rubber for quieter placement in Kallax compartments?
Created on: 16 Feb 2021 09:12
liamreo
Hello everyone, I am currently considering lining my Kallax shelving compartments with foam rubber to make placing boxes or storage bins inside quieter. Has anyone had experience with this? I’m particularly interested in whether foam rubber noticeably reduces noise compared to other materials like felt or foam, and if it remains stable enough so the boxes don’t wobble. I would also like to know if the foam rubber needs to be cut to size or if there are special pre-cut pieces available for Kallax. Thanks in advance for your feedback!
liamreo schrieb:
How stable are the boxes when using, for example, Ikea plastic boxes? The Ikea plastic boxes are very stable for me, but I fixed the foam rubber with double-sided tape. This prevents any slipping and keeps the surface level. With thinner foam rubber, nothing tips over for me either, but it needs to be 2-3 mm (0.08-0.12 inches) thick to noticeably feel the cushioning effect.
For everyone who wants to use foam rubber in Kallax compartments, here is a brief guide:
1. Material selection: Choose foam rubber with a thickness of 2–3 mm (0.08–0.12 inches) for optimal cushioning with minimal loss of space.
2. Cutting: Measure precisely and cut with a utility knife or sharp blade. A ruler helps to achieve straight edges.
3. Attachment: I recommend double-sided tape because it stays clean. Alternatively, spray adhesive can be used, but it is harder to remove without residue.
4. Slip resistance: For smooth boxes, slip-resistant foam rubber can help; otherwise, place thin rubber mats underneath.
5. Cleaning: Foam rubber is easy to clean with a damp cloth, which helps to remove dust.
Summary: Foam rubber is effective, inexpensive, and easy to work with. Pay attention to thickness and don’t forget to secure it, otherwise it will shift.
LANICOLE schrieb:
Summary: Foam rubber is effective, affordable, and easy to work with. This matches my assessment. How about durability in your experience? Does foam rubber become brittle or start to break down after months or years? I don’t want to have to replace it frequently.Also, I’m curious if anyone has long-term experience with different qualities of foam rubber, for example cheap craft foam versus specialized sealing foam rubber from a hardware store.
FRANCISCOP17 Feb 2021 09:28liamreo schrieb:
How durable is it in your experience? Does foam rubber become brittle or start to break down after months or years? Usually, foam rubber made from ethylene propylene diene monomer (EPDM) is very durable and barely ages under normal indoor conditions. However, cheap, porous craft foam rubber can become brittle after a few years. For long-term use, I recommend good quality hardware store products with UV resistance, even if they are slightly more expensive.
