ᐅ Experience with Ventilation of Roller Shutter Boxes: Aereco Zuroh 100
Created on: 8 Mar 2018 09:47
Malz1902
In our house, ventilation units are to be installed in the roller shutter boxes in the four rooms in the attic—dressing room, bedroom, Child I and Child II—as well as in the kitchen and living room. Specifically, Aereco Zuroh 100 units. Does anyone have experience with these and can share their opinion? Are they worth it?
Our site manager says we don’t necessarily need them, but if we want them, they will be installed.
Tolentino27 Jun 2022 18:17
You, if the ventilation system has a heat recovery unit without a bypass function. Then it reheats the incoming outside air on the left side nicely. This is desirable in winter and saves heating energy, but it can be really annoying in summer.
Maybe there is a button or a malfunction for this after all?
RotorMotor
27 Jun 2022 18:22
But the mentioned option doesn’t have any heat recovery system at all, does it?!
driver55
27 Jun 2022 19:25
Tolentino schrieb:
You, if the ventilation system has a heat recovery unit without a bypass function. Then it warms the incoming outside air nicely again. This is desirable in winter and saves heating energy, but it's really annoying in summer.
Maybe there’s a button or a malfunction for that?
That is just a defined slot in the roller shutter box, nothing more. No heat recovery at all. Looking at the picture, the box measures about 20-25cm (8-10 inches) and has a rotary knob for manual ON/OFF, otherwise it operates "automatically". That’s it.
@Jamastau: So in this case, about 17 degrees Celsius (63°F) cold air should flow in when you set it to ON.
Jamastau
27 Jun 2022 20:37
Yes, that's right—a box with a slot and even a button to close it tightly. I ventilate for hours at 18°C (64°F), and the temperature still stays at 25°C (77°F).
The cheapest of the cheap was installed there by the builder. You always learn afterward.
But I have since researched and found new indoor cover plates with a button for retrofitting the Zuroh 100 to Zuroh 110.
Let's see if that improves the situation.
Thanks for the responses.
Jamastau
27 Jun 2022 20:39
Addendum to the 2nd sentence should read WITHOUT button
driver55
27 Jun 2022 21:07
And again. This has nothing to do with it.
Thermal insulation and shading are the "magic words."
Describe the building. Wall construction? Is the apartment completely on the south side? Attic?
