ᐅ Replacement of Old Night Storage Heaters with Modern Electric Heating Systems
Created on: 9 Nov 2017 08:18
MaxPower90
MaxPower909 Nov 2017 08:18
I own and rent out a 20m² (215 sq ft) apartment, which is heated by a night storage heater from 1995. The unit looks quite ugly, and controlling a night storage heater is very inconvenient since you basically have to select your desired heating output a day in advance. Additionally, it has a fan, and my tenant keeps complaining because the noise bothers her.
I could have the unit removed for €100 and install a modern electric heater for another €100. In my opinion, this makes sense, as I believe the new heater would operate more efficiently than a 20-year-old night storage heater. Night storage electricity costs about 20 cents per kWh here, compared to regular electricity at around 25 cents per kWh. The savings aren’t huge, and choosing this option limits your choice of electricity providers quite a bit.
How do you all assess this situation?
Alex85
9 Nov 2017 12:26
Ask your tenant. She has to cover the 20% higher consumption costs, right?
Otherwise, if the heating output is sufficient, why not?
Keep in mind that it won’t look good under the stove once you remove it. You might need a few more euros to spruce up the floor there.
Deliverer
9 Nov 2017 14:52
Also keep in mind that the efficiency of electric heating has always been very high, so there probably hasn’t been much change. (Even the earliest incandescent bulbs were almost 100% efficient heating elements ;-)
What you might save could only be the heat loss from storage during the night.
But that’s just my layman’s opinion – the heating engineer can definitely tell you more about this.
Alex85
9 Nov 2017 18:03
He was more concerned about the ugly tank barrier and the lack of comfort
Bau-Schmidt
9 Nov 2017 19:03
What kind of electric heater can you get for 100 €?
meister keks
11 Nov 2017 23:23
Hello.
Have you ever considered whether one or two infrared panels might be the right solution?
