ᐅ Evaluation of floor plan for approximately 145 sqm single-family house with basement, ground floor, and upper floor
Created on: 14 Oct 2021 12:44
Arango18
Zoning plan/restrictions: Zoning plan and restrictions considered by the architect
Plot size: 675m² (7260 sq ft)
Slope: yes, running diagonally across the plot (see elevation plan)
Building window, building line and boundary: 3 m (10 feet) on all sides
Edge development: yes, neighbor to the southeast
Number of parking spaces: 2 in garage and 2 in front of garage
Number of floors: 2.5
Roof type: gable roof, 36 degrees
Architectural style: simple
Orientation: southwest
Maximum heights/limits: same as neighboring buildings, sufficiently high
Other requirements: none
Street: cul-de-sac; our house is at the end, with neighbors on one side and open view of forest, meadow, and valley on the other
Owners’ requirements
Style, roof type, building type: interior as open and straightforward as possible, exterior simple
Basement, floors: basement, ground floor (GF) and upper floor (UF)
Number and age of occupants: currently 2 (both 28 years old), planning 1-2 children
Space requirements for GF, UF: approx. 140 m² (1507 sq ft) of living space
Office: absolutely necessary due to 80% remote work
Guest bedrooms: very rare use
Open or closed layout: open
Conservative or modern construction: conservative (mostly because it’s usually more affordable)
Open kitchen, cooking island: open kitchen with bar or island (due to space and layout, more likely a bar)
Dining seats: 4-6
Fireplace: planned but not mandatory
Music/stereo wall: standard TV wall
Balcony, roof terrace: small terrace on the slightly extended garage towards southwest, terrace towards southeast
Garage, carport: double garage with a single door
Utility garden, greenhouse: standard
Other wishes/notes/daily routine, including reasons why some things are wanted or not: a small shower in the guest WC is very important to us, as well as a small room for the home office. Since I work from home 80% of the time, this is essential. Also, a small storage room for vacuum cleaner etc.
Who designed it: architect
What do you particularly like? The dining and living area looks bright and cozy in our opinion. Not too big and not too small with a great view.
What don’t you like? Why? Bathroom layout feels too tight and awkward, hallway in the upper floor too narrow?
Preferred heating system: air source heat pump
If you had to give up some features, which ones?
Fireplace
Why did the design end up like it is now?
The original design was larger and included more details such as corner and roof windows, but it was optimized for cost.
However, the room layout and overall room concept basically remained unchanged.
I would appreciate further suggestions, especially regarding the aspects we don’t like. Overall, we are quite happy with it. Do you see any major “no-gos”?
If any information is incomplete or unclear, I’m happy to check it again.
Technischer Plan: rotes Quadrat Nr. 4 in der Mitte, blaue Grenzlinie, gelbe Markierungen.
Lageplan: Parzellen mit Größenangaben (675, 660, 389, 512, 585 m²) und Straße.
Grundriss Erdgeschoss mit Eingang, Gäste-WC, Diele, Abstellraum, Kamin, Wohnen/Essen, Terrasse.
Kellergeschoss Grundriss: Garage, Büro/Gast, HWR, HAR, Flur, Treppenhaus.
Grundriss Dachgeschoss mit Flur, Bad, Eltern, Ankleide, Kind I, Kind II, Terrasse.
Hangman25 Oct 2021 11:51
@Arango18 The current planned orientation parallel to the street means that the house is basically positioned diagonally on the slope... and it reminded me that there is a good example of this in the forum as well: https://www.hausbau-forum.de/threads/grundrissentwurf-efh-hanglage.37183/post-498594
Arango18
25 Oct 2021 12:29
Hi @Hangman, exactly. I just took a look at it and I basically like it a lot. :-) The problem here is that we can't really come to terms with a bathroom "below ground," without natural light or windows (I'm generally not a fan of light wells) :-(
JayneCobb
26 Oct 2021 02:17
Hello @Arango18, I am one of the builders of the house quoted by Hangman.
Glad to hear our floor plan is well received! 😀
Regarding the bathroom: Trust me, I definitely don’t want to have my bathroom in a dark, windowless space.
Of course, a light well isn’t the same as a “window with a view” (which would be fantastic), but I’m aiming for at least an attractive alternative since I want it to have natural daylight and be ventilated (although at the moment we are leaning towards a central ventilation system).
Let’s see what reality brings. 😎
Happy planning!
11ant26 Oct 2021 14:02
JayneCobb schrieb:
Of course, a light well isn’t a "window with a view" (that would be really great),
You could install a mirror, then you’d be able to see the sky 🙂
