ᐅ Ethernet wiring was forgotten – wiring?
Created on: 7 Nov 2018 08:56
Der-w
we are about to buy a house from a developer. Unfortunately, they forgot or decided not to install star-topology Ethernet cabling.
I’m not yet sure if I want or can completely do without it.
So here is my idea for the wiring, and I would appreciate your constructive feedback:
Sketch of a multi-story home network distribution with switch, router, and Wi-Fi
There is an empty conduit from the basement to the upper floor (originally intended for photovoltaic system preparation) that I would like to use to pull a cable (possibly duplex) to the upper floor and distribute it there with a switch. I want to pull only one cable to keep space available in the conduit for future use.
From the basement to the lower ground floor, a new hole would need to be drilled and a cable pulled up to distribute there by switch as well.
Am I missing something in my wiring plan? Cascading switches should actually allow this, right?
Do you see any major problems or performance limitations?
Thanks for your help.
Mottenhausen
7 Nov 2018 13:36
That's right, my mistake, at 1000 Mbit all 8 wires are actually used.
Steffen80
7 Nov 2018 14:23
Nothing beats Ubiquiti UniFi when it comes to Wi-Fi performance 🙂
Caspar2020
7 Nov 2018 17:28
Der-w schrieb:
Do you see major issues and performance limitations?
Not in real life.
Mottenhausen schrieb:
Well, if fast-paced online games are played, the kids won’t be happy about an additional 5-10 milliseconds (ms),
Normal switches forward data with a maximum delay in the double-digit microsecond range. Ping times, on the other hand, are measured in milliseconds (ms).
To reach 5-10 ms delay, you’d have to cascade a large number of switches.
rick20187 Nov 2018 19:36
How much money can or do you want to invest?
If it’s about space, fiber optic could be an option. Otherwise, Cat7 duplex cable (do not cascade).
I would also recommend Ubiquiti Unifi. It’s best to get the switches as well.
For speed, 10Gb switches are possible but that might be overkill.
For example:
3 x US-8-60W or US-8 if you don’t need PoE on some floors
1 x Cloud Key
Access points depending on your requirements and conditions.
As a router, a USG
This way, you would have a complete system that can be managed centrally and easily. VLANs and other configurations would also be straightforward.
If your demands are not high, unmanaged switches (20-40€ per piece) are sufficient. Naturally, you would need additional equipment for the Wi-Fi.
11ant7 Nov 2018 19:38
Der-w schrieb:
Unfortunately, they forgot or saved on installing star-topology Ethernet cables.
You poor thing, nowadays that’s almost like running a toilet pipe across the yard :-(
Der-w schrieb:
That’s why my idea for the wiring
I would say the temporary solution is hardly any worse than a planned one. I don’t see any mistakes.
Der-w schrieb:
There are TAE sockets in every room (sometimes even several) with regular telephone cables.
So? – how different are their lengths, can you also add two fours and get eight?
Der-w
7 Nov 2018 19:49
The cables are located in two corners, so it will be difficult... and then there’s the shielding issue. I think that if the phone cables are not disconnected, which I assume, I will go ahead with my temporary solution (have it done). I’m a bit nervous about drilling from the basement to the lower ground floor. There is underfloor heating there.
