ᐅ Fitting a Billy Bookcase with Castors – Should Stability Be a Concern?
Created on: 11 Oct 2024 08:37
Daronan
I am considering fitting a Billy bookcase with casters to make it more movable within the room. However, I’m not entirely sure which stability factors I need to pay attention to. I have the following questions in particular:
- Does the bookcase lose stability when fitted with casters, especially under heavy loads or when it is moved?
- Are there specific types or sizes of casters that are especially suitable for a Billy bookcase without compromising its stability?
- Is it necessary to add additional reinforcements to safely place the bookcase on casters?
I look forward to your experiences and tips, especially if you know technical details or tricks to keep the bookcase stable. Thanks in advance!
Daronan schrieb:
The shelf is a standard Billy unit with a height of 202 cm (79.5 inches), approximately 80 cm (31.5 inches) wide and 28 cm (11 inches) deep.This makes the requirements somewhat more demanding since the shelf is most prone to tipping due to its height. Pay special attention to the following points:
- Install casters with locking brakes to ensure stability when stationary.
- The casters should be attached at the sturdiest possible points, preferably at the outer edges of the shelf, to minimize leverage effects.
- Adding a cross brace at the back or securing the unit to a wall if possible will provide greater stability.
With an 80 kg (176 lb) load of books on a 202 cm (79.5 inches) tall shelf, additional reinforcements are definitely recommended.
An important factor is also the material of the casters. Rubber casters are somewhat softer and protect the floor but tend to wobble slightly. Plastic casters are harder and provide more consistency but transfer unevenness more strongly. For a relatively tall shelving unit like Billy, I recommend casters with rubber coating, combined with locks to increase stability without losing mobility.
I would like to add that the screw connections of the rollers should be tightened especially firmly to avoid any play. Regular retightening can help ensure long-term stability.
Additionally, a base plate can be installed inside at the bottom of the shelving unit, which acts as extra weight and counterbalance. This lowers the center of gravity, making tipping more difficult. Have you considered whether this might be an option for you?
Dilen schrieb:
You can also install a base plate on the inside bottom of the shelf, which acts as additional weight and counterbalance.Interesting tip, I hadn’t considered that before. I could use a thin MDF board and load it directly with books. Would it be better for such a “base plate” to be fixed permanently or simply placed loosely? I don’t want to modify the shelf too much.
Daronan schrieb:
Would such a “floor panel” be better installed fixed in place or laid loose?From a technical point of view, a fixed installation is better because it makes the structure more rigid. Panels laid loosely could shift and do not help stabilize the frame. If you don’t want to alter the shelf too much, a panel screwed under the shelves would be ideal, and it can be removed again if necessary.
Alternatively, a metal angle bracket fixed at the bottom inside of the cabinet can also help with stabilization, depending on your level of DIY skill.
