ᐅ Energy Savings Through Improved Bricks
Created on: 30 Jan 2020 20:07
hegi___
I couldn’t find any calculation on whether better-insulated bricks are really worth it, so I calculated it myself using Ubakus:
House data: Ground area 10 m x 9.5 m (33 ft x 31 ft); room height 2.5 m (8 ft); location Munich (cold region); wall area: 221 m² (2,378 ft²)
Energy loss of the wall with the following U-values:
U = 0.23 = 4135 W/year
U = 0.21 = 3809 W/year
U = 0.18 = 3320 W/year
U = 0.17 = 3163 W/year
Assuming a heat pump with a seasonal coefficient of performance (COP) of 4 and electricity cost of 0.27€ (per kWh), the differences in energy costs compared to the least efficient bricks (0.23) are:
0.23 = -
0.21 = 22 € / year; 880 € / 40 years
0.18 = 55 € / year; 2200 € / 40 years
0.17 = 65 € / year; 2620 € / 40 years
Example bricks: Poroton Wienerberger List prices 36.5 cm (14.4 inches)
Required bricks: 3500 pieces
0.23 = 5.6 € per piece
0.21 = 6 € per piece; total extra cost: 2100 €
0.18 = 6.3 € per piece; total extra cost: 2450 €
0.17 = 6.7 € per piece; total extra cost: 3850 €
So somehow, I don’t see a significant advantage in using better bricks, especially if you live in a warmer region.
Map of Germany with color gradient of design temperatures (-10°C to -16°C, blue to red).
Scout
1 Feb 2020 10:32
I am generally in favor of insulation, but I like to play the devil’s advocate.
Disadvantage: If you consider the external volume as fixed, the living space decreases by 1 m² (11 sq ft) for every 2.5 cm (1 inch) increase in wall thickness. This applies per floor, of course.
For a two-story building, that means 2 m² (22 sq ft) less living area, or roughly 2400 euros more in construction costs in a general calculation... with a 5 cm (2 inch) thicker wall, it would be twice as much, and so on.
hegi___
1 Feb 2020 11:18
Specki schrieb:
Some arguments have already been mentioned as to why this could still be worthwhile.
- KfW funding!!!
- Resale value
- Smaller heat pump
- Possibly less underfloor heating piping
- etc.
I’d like to add another point.
Your financial loss calculated over 40 years is only €1230. That’s negligible! For me, that alone would be worth paying for the extra cost in terms of ecological conscience.
And finally, I can tell you that your calculation is probably incorrect. I would assume an annual electricity price increase of 1 to 1.5%. That makes the situation look even better.
So, from my perspective, a clear recommendation in this case: The block with the lower U-value pays off!
Regards
Specki
The heating load savings are only 372 watts. For 150m² (1600 sq ft), that’s 2.5 W/m² (0.23 W/sq ft).
0.17 → 1056 W
0.23 → 1428 W
You won’t save much either on underfloor heating or on the heat generator.
The energy cost increase becomes irrelevant if you finance and have to pay 1% interest on the additional costs.
Scout schrieb:
I’m generally in favor of insulation, but I like to play devil’s advocate.
Disadvantage: If you assume the external volume is fixed, the living area decreases by 1 m² (11 sq ft) for every 2.5 cm (1 inch) thicker block—per floor, of course.
For two stories, that means 2 m² (22 sq ft) less living space, or about €2400 more building costs in rough calculation… with a 5 cm (2 inch) thicker block, it’s double that, and so on.
All U-values are based on 36.5 cm (14 inch) blocks. You don’t necessarily have to switch to larger ones.
Exterior wall, window, and roof thermal performance table with overall demand (kW)
Snowy36
1 Feb 2020 11:47
We chose the thicker brick purely for aesthetic reasons... and we like thick reveals... plus, when I saw how much was sometimes cut out of the 42.5cm (17 inches) ones for pipes and such, I was very glad we went with it.
