ᐅ Empty conduit from the utility room to the attic, 50 mm – sufficient
Created on: 5 Jul 2016 09:06
netti
I am currently wondering if an empty conduit with a diameter of 50mm (2 inches) from the utility room to the attic is sufficient. The satellite system cables are to be installed through it.
Does anyone have experience with this?
Thanks
Sebastian79
10 Sep 2016 11:03
Expanding foam is not airtight – if you use HT pipes, you can simply seal them.
Sackkarre
10 Sep 2016 11:22
Sebastian79 schrieb:
Construction foam is not airtight – if you use HT pipes, you can simply seal them.
In our case, the empty conduits are laid as corrugated pipes. How can I seal them airtight? Another option might be duct tape, but that probably won’t be a long-lasting solution either.
Maybe spraying acrylic or silicone? But with the 40mm (1.6 inches) pipe, that might not work very well either, right?
Sebastian79
10 Sep 2016 11:41
Yes, I would use tape – plenty of it, but no expanding foam, it’s messy anyway...
