ᐅ Electrical installation too expensive – oversized or just overpriced?
Created on: 5 Oct 2015 14:57
derelvis
We received the quotation for the electrical installation, and I had to sit down first.
So far, everything has roughly matched the values found online (excavation, surveying, structural engineering, architect fees, etc.), but the electrical installation is about twice as expensive as what is generally indicated on the internet: €23,000, while we had planned for €10,000–12,000.
On closer inspection, we noticed that the quotation seems oversized and appears to cover all possible contingencies. The final billing is based on actual usage, so I would like to get your opinion on how over-dimensioned it really is. The prices include installation.
A few items can be deducted or reduced considerably. (For example, I do not need 17 temperature controllers with displays at €100 each), which would save about €1,000 right away. Also, a network cabinet with a patch panel listed at €400 can be found for about half that price. Having 110 sockets plus 10 Schuko sockets also seems excessive to me.
There are also elements included that I have not seen elsewhere: all installations (kitchen, heating, garage), roller shutter control and connection, ventilation installation, mailbox with intercom system. Still, I cannot get the total below €15,000, let alone €10,000.
Here are my top 10 items – is this very oversized? Or am I unlikely to save much? Especially the cable lengths are about double what I see online.
Room temperature controller €104.12, 17 pcs, €1,770.04
Sheathed cable 5*1.5 mm², €1.83 per meter, 700 m, €1,281.00
Socket outlet Jung AS520, €9.25, 110 pcs, €1,017.50
Meter cabinet €856.34, 1 pc, €856.34
Sheathed cable 3*1.5 mm², €1.41 per meter, 600 m, €846.00
Mailbox system with intercom €568.49, 1 pc, €568.49
Electronic transformer €29.43, 14 pcs, €412.02
Silicone protective cap €26.10, 14 pcs, €365.40
FR bathroom light €58.38, 6 pcs, €350.28
Residual current circuit breaker €68.26, 5 pcs, €341.30
Roller shutter: programming €338.71, 1 pc, €338.71
daniels8725 Jan 2016 11:13Peanuts74 schrieb:
Vacuum cleaner plus a few other appliances, such as a waterbed heater, etc.But you don’t vacuum for several hours straight.
And a sound system has a short power surge. You can neglect that.
Your ears are more likely to get damaged than the cables inside the wall.
Sebastian7925 Jan 2016 11:15We’ve already discussed this topic here – a 2000-watt sound system does not equal electrical consumption.
My not exactly small Pioneer uses around 150 watts, my TV up to 400 watts at most – there’s still a lot of room up to 3600 watts.
Peanuts7425 Jan 2016 11:18Just kidding. Of course, you don’t have 2000 watts of audio power in the living room *lol*
daniels8725 Jan 2016 11:28We already had a 40kg (88 lbs) PA amplifier with two large 2x15" bandpass horns running in the living room. Apart from the amplifier clipping, there were no issues. About 3000W RMS must have been output.
So, no problem at all.
