ᐅ Garage Electrical System: Circuit Breaker Panel, Electrical Circuits, Outlets
Created on: 19 Sep 2017 07:49
bauerle
Our house is slowly but surely taking shape, and of course, the double garage must not be missing. Since we built the garage ourselves, the electrical work is also our responsibility. I’m not going to mess around with it, but I’d like to know in advance what makes sense.
Chasing the walls for cables and laying them is manageable.
For the garage, I am currently considering two approaches:
Two separate electrical circuits in the garage:
One circuit to power the six outlets distributed throughout the garage
A second circuit for two lighting circuits; one controlled by a motion sensor that automatically turns the garage lights on and off depending on the brightness (access to the house through the garage is possible), and a light switch that controls a constant light with multiple fluorescent tubes for when working on projects in the garage.
Does this have to be done with two separate circuits, or is a single circuit distributed via a junction box sufficient here?
Should a separate fuse box (distribution board) be installed in the garage, or is it sufficient to protect everything from the main fuse box in the house?
Thanks and best regards
Georg
benutzer 1004
9 Sep 2019 07:21
Then you need to have a three-phase 400V/32A supply installed for the 22 kW. However, your household connection must first support this, and the utility provider needs to agree. If that is not possible or too expensive, in my opinion, 400V/16A, which is 11 kW, is sufficient for electric mobility. You are not just at home for one hour, where your car needs to charge from 0 to 100%. It stays there longer (at least about 8 hours overnight), so 11 kW is more than enough. Especially since there are considerations in the future to charge based on actual power consumption, meaning charging will likely be done at the necessary speed rather than the maximum possible.
ti-mar90
9 Sep 2019 07:24
BigFoot schrieb:
Then you need to have a three-phase 400V/32A connection installed for the 22 kW. However, your main electrical connection must first support this, and the utility company has to approve it. If that’s not possible or too expensive, in my opinion 400V/16A, which equals 11 kW, is sufficient for electric mobility. You’re not just at home for one hour, needing to charge your car from 0 to 100%. It will be parked longer (at least about 8 hours overnight), so 11 kW is more than enough. Especially since there are considerations in the future to charge based on the required power rather than the maximum possible speed.
Thanks! I’ll take these values with me and see what the utility company says about the 32A.
pffreestyler
12 Sep 2019 07:58
I’ll join the discussion here as well... I initially neglected the topic of the electric car. Although I mentioned at the start that we wanted to prepare for it, I didn’t follow up during the construction rush. Since we don’t have a shed yet, it wasn’t really necessary at the time. The electrician just gave me a thick underground cable, which I didn’t question further. The civil engineering team laid it together with the conduit for fiber optic as part of the multi-utility duct. Now I checked, and it’s only 5 x 1.5 mm (5 x 0.06 inch). For my current needs—just 1-2 sockets and 2 lighting points in the shed—that’s more than enough. The downside is that it won’t be sufficient for an electric car charger that will likely come at some point. The multi-utility duct is already fully occupied, so eventually I won’t avoid an unsightly core drilling, and I’d rather not replace the 5 x 1.5 mm cable. I don’t want to tamper with the multi-utility duct, and high-current cables in the same duct as fiber optic aren’t good for internet performance anyway.
What cable do I need for an electric vehicle charger? 5 x 6 mm (5 x 0.24 inch) or 5 x 10 mm (5 x 0.39 inch)? I’m considering laying the cable now from the exterior wall of the utility room to the exterior wall of the shed, or even in the shed’s floor slab, before paving and building the shed next year. I’ll have to dig the trench for the 5 x 1.5 mm cable anyway, so it would be easy to do it at the same time.
world-e
12 Sep 2019 08:41
pffreestyler schrieb:
High-voltage power cables in the same multi-utility conduit as fiber optics are said to negatively affect internet performance.
This has no impact on each other because fiber optics transmit data through light signals, which are not affected by other electromagnetic fields.
What type of cable do I need for an electric vehicle charging station? 5 x 6 mm² or 5 x 10 mm²?
You can’t say that in general; it depends on the length and the power output of the charger. I would recommend at least 5 x 10 mm² (5 x 0.02 inches), as the additional cost is negligible. Sometimes 5 x 16 mm² (5 x 0.03 inches) is even better because it usually has multiple strands, making it easier to install.
gmt94
12 Sep 2019 09:01
So we installed a 5 x 16mm2 cable based exactly on the same requirements. This should be sufficient. However, you won’t be able to charge two Teslas with Superchargers simultaneously, as your main electrical connection can’t support that at all.
world-e
12 Sep 2019 09:03
gmt94 schrieb:
We used exactly the same specifications and installed a 5*16mm2 cable. That should be sufficient. However, you won’t be able to charge two Teslas with superchargers at the same time, as your main power supply can’t handle that.
It’s likely that the circuit protection from the street or residential area won’t support simultaneous fast charging for all houses with superchargers or similar setups. But fast charging at home is rarely necessary. Usually, there’s enough time to charge slowly overnight.
