ᐅ House electricity consumption – what is your usage?
Created on: 6 Oct 2020 06:29
chewbacca123
Good morning everyone,
I wanted to ask what your house’s electricity consumption is at night when everything is quiet and sleeping, so what is running continuously?
We have a newly built house, moved in summer 2019. Our building services include underfloor heating (air-to-water heat pump), controlled mechanical ventilation (runs at full power 3 times a day for 2 hours each, then reduced), a photovoltaic system, and otherwise the usual nighttime appliances (phone charger plugged into USB outlet, e-bikes charging occasionally, 2 TVs on standby, Alexas on standby, etc.).
At night, we have a continuous consumption of about 232W (with ventilation running at reduced power and when the heat pump is not producing). I can see this in the app for the photovoltaic system. From 0:00 to 6:30 a.m. we consume about 2.8 kWh.
How about you?
Z
Zaba12
21 Dec 2020 09:11
Zaba12 schrieb:
Besides, I want to extend the heating cycles!
What I actually mean is that I want to reduce the number of cycles within 24 hours to lower the heat pump’s energy consumption.
Daniel-Sp
21 Dec 2020 12:06
Is the heating circuit pump controlled by the heat pump?
An 8K temperature difference in the heating circuit at 0°C (32°F) outdoor temperature is somewhat high. 4.5K would be better.
Which heat pump do you have, and is it a modulating heat pump?
Creating a separate thread would be more appropriate to avoid distracting from the original topic.
Z
Zaba12
21 Dec 2020 13:22
It is an AI LWD70a, return-flow controlled. The question is, what can cause such a temperature spread? It only occurs during heating operation. I understand that a low temperature spread is desirable, meaning below 5°C (41°F). But what causes the temperature spread, I don’t know.
Bookstar
21 Dec 2020 13:43
25 kWh is not too bad at 0°C (32°F). However, I think just under 20 kWh should be achievable.
I currently see the issue with the hydraulic balancing. You need to regulate the flow rate. This requires a lot of patience and trial and error.
Z
Zaba12
21 Dec 2020 14:02
@Bookstar
The minimum flow rate of the heat pump is 1200 l/h (5.3 gallons per minute). The nominal flow rate should be 1600 l/h (7 gallons per minute). The system is designed to heat the two basement rooms (3 heating circuits), which are currently off because I don’t want to heat the remaining 38 m² (409 sq ft) without underfloor heating using just 32 m² (344 sq ft) of underfloor heating. Maybe this is where the problem lies?!
I also think that even if the basement were heated, the ground floor wouldn’t be as warm. But if I heat the basement, the energy consumption will increase, right?
@hydraulic balancing: I’m not sure; the flow rates don’t seem too far off.
Currently, the flow rate without the basement is 1347 l/h (5.9 gallons per minute), and with the basement, the 1600 l/h (7 gallons per minute) target should actually be reached.
But before I open the basement heating circuit, I’ll monitor the consumption and temperature with the new heating curve over the next two days.
Daniel-Sp
21 Dec 2020 17:30
Can you still increase the flow rate in the heating circuit? You should have a lower temperature differential at 0°C (32°F) outdoor temperature. Can the heating circuit pump be pushed harder?
