ᐅ Electrical Installation During the Shell Construction Phase
Created on: 20 Apr 2017 14:48
Hendrik007
I need to finalize the electrical planning for my new apartment construction soon. I have already incorporated many great ideas from the forum, such as bedside lamps that can be switched from the door. Thanks for that.
Now I would like to ask the experts here if they know of any other useful tips. Sometimes a small effort during the rough construction phase can have a big impact, or you only realize after completion what could have been done better or differently.
Basically, the following is planned for our 4-room ground-floor apartment:
Do you have any additional ideas?
- Power outlet in each room below the light switch
- Double power outlets in all corners of the living and bedrooms
- Sixfold power outlets where the TV will be mounted on the wall, plus empty conduit for the wall-mounted TV
- In the living room, two outlets near the entrance will be switchable for lamps (or Christmas lights)
- The same setup in the bedroom for the bedside lamps
- In the bathroom: double outlet by the mirror and in a corner where bathroom furniture will be placed, as well as under the heater and power supply to the toilet to prepare for a shower toilet
- Double outlet on the terrace and a power cable to the back of the garden (where a garden shed will be built eventually) – all switchable from inside
- Outdoor power above the terrace door in case a retractable awning is installed there
- Network cables laid in a star topology to each bedroom and the TV corner, running to the router in the storage room
- Obviously, plenty of power outlets in the kitchen
- Roller shutter switches by each window and one central switch in the hallway for all
- TV connections in each bedroom and the living room
- Telephone and internet connection point in the storage room
Hendrik00725 Apr 2017 13:36And what does Accesspoint stand for? AVM doesn’t have one, right?
Hendrik007 schrieb:
And what does access point stand for? AVM doesn’t have those, right?Access point – that is a device category, in German: Zugriffspunkt.
Äckßäßß Peunt That must be seriously hilarious...
Caspar202025 Apr 2017 15:37The Fritz repeaters can do that as well. This feature is called a LAN bridge.
And above all, they can share the settings from the Fritz box.
Hendrik00725 Apr 2017 16:39Wouldn't a LAN bridge be created if I connect a device to the repeater using a network cable? I actually want to connect the repeater to the LAN...
Caspar202025 Apr 2017 19:37The mode also exists. However, it is called WLAN Client Mode.
With LAN Bridge, you do exactly what you described last. AVM also provides colorful diagrams.
