ᐅ Electrical connection in the bathroom or for a mirrored cabinet
Created on: 10 Dec 2018 13:05
Gerd&JolantheG
Gerd&Jolanthe10 Dec 2018 13:05Hello,
I am currently planning the electrical installation in our shell construction.
Now I have reached the bathroom, and we would like to install a mirror with integrated lighting.
So, my questions are:
1. At what height should I install a flush-mounted box? There are installation zones, but I can’t find a specific height for the bathroom.
2. Should I install a socket that is controlled by a switch located to the right of the washbasin, or should I install a cable with connector blocks?
Thank you all.
Thank you all.
Cable with terminal. The cable can be switched via a light switch. The cabinets are delivered with cable but without a plug. The cable must come from the wall behind the cabinet so that it is not visible when the cabinet is installed. The cabinets have a hollow space at the back for cable management.
Gerd&Jolanthe10 Dec 2018 13:35Yes, thank you very much.
I will install a flush-mounted box centered above the basin, at a height of 1.70 meters (5 feet 7 inches) above the finished floor.
Gerd&Jolanthe12 Dec 2018 10:37Domski schrieb:
A flush-mounted wall box is quite luxurious! That fits perfectly.Is that a standard flush-mounted box?
