ᐅ Electrical Wiring – Where Is It Safe to Drill?
Created on: 27 Dec 2020 11:09
Fragenasker
I am a complete beginner: But how do you know where you are allowed to drill, for example in ceilings for light fixtures or in walls for pictures – especially if you have purchased an existing property built in 2016? According to VDE standards, the electrician should have installed cables 30cm (12 inches) above the floor or below the ceiling. But if the power cable for a lamp is hanging down vertically from the center of the ceiling – how do I know where I can drill without hitting the cable? Any tips or tricks?
Joedreck
27 Dec 2020 11:54
As mentioned: buy a detector. The cable comes from the wall where the switch is located. If the electrician did everything correctly, it will run at right angles and straight. So, not diagonally from the switch position to the fixed point.
bauenmk202027 Dec 2020 21:33
Is it actually safer to drill using a corded drill connected to a power outlet (same electrical circuit) instead of a cordless screwdriver when there is a risk of drilling into an electrical cable?
Joedreck
27 Dec 2020 22:41
Um, safer is to switch off the circuit breaker, check that it is off, and secure it against being switched on again...
Winniefred27 Dec 2020 22:54
I hope it’s obvious to everyone that the power should be switched off beforehand 😱
27 Dec 2020 23:13
Winniefred schrieb:
Hopefully, it’s obvious to everyone that the power should be turned off beforehand 😱
I’ve never turned off the power before drilling, at least not when drilling into walls. However, I would do it when working with a light fixture.
O
Olli-Ka
28 Dec 2020 06:06
what should change with a corded drill?
The cable doesn’t care whether it’s being drilled by a battery-powered drill or a corded drill.
If you cause a short circuit, the circuit breaker trips, the drill stops – but the cable is still damaged!
If you hit the neutral and/or the protective conductor, nothing happens.
If you only nick a live wire, it could be dangerous, not during drilling, but later when you screw something in; the screw and the attached component could be live.
The problem is: at first, you won’t notice anything, no breaker trips, everything seems normal.
It’s unpleasant if you’re, for example, attaching a bathtub grab bar or something similar.
That’s why RCDs (residual current devices / ground-fault circuit interrupters) should always be installed.
Regards, Olli
