ᐅ Ground floor and upper floor built with masonry—why pour a concrete basement?
Created on: 18 Jul 2016 12:52
blumingerHello.
Why is the basement often made of concrete instead of masonry, even though the ground floor and upper floor are built with masonry?
On the ground and upper floors, you often see monolithic construction with bricks, while the basement has a multi-layer structure with concrete and external insulation, which the builders clearly chose not to use above ground.
What are the pros and cons of this approach?
Greetings from Swabia.
toxicmolotof18 Jul 2016 13:18Next point: Earth pressure
Not every stone likes that.
