ᐅ Duration of Shell Construction – Construction Waste Container
Created on: 4 Sep 2019 19:11
Andre77Hello,
once the foundation slab is completed, how long does it usually take before masonry work begins? I would also like to know approximately how long it takes to finish a timber frame structure. I assume it is practical to have a construction waste container on site at the start of the masonry work, or are there other suggestions? Is the container typically kept on site for the entire duration of the shell construction, or is a new container brought in later? Perhaps someone can explain the usual procedure here.
Thank you!
Thank you!
Debris is not all the same, and if you're unlucky, the container will be charged as mixed construction waste. Then you might pay €250 or more per ton. You really have to be careful about who disposes of what there.
The rental period is less important; here I pay 50 cents per day.
Just a moment, regarding the daily rate, of course there is also the travel cost and the first x weeks free. That’s the only aspect where all the companies here differ slightly. They all transport the debris themselves to the same disposal facility, so the prices are the same there.
nordanney4 Sep 2019 21:32Andre77 schrieb:
Once the foundation slab is completed, how long does it usually take before brickwork starts?A few daysAndre77 schrieb:
I assume it’s practical to have a construction waste container ready at the start of the brickwork?For what purpose? We didn’t have one during the entire construction. I also don’t recall our neighbors in the development having one.Here, each tradesperson simply took their waste with them properly (which is really manageable on a daily basis). There isn’t much waste generated anyway.
