ᐅ Durability of black door handles?
Created on: 12 Mar 2025 11:12
Hausbauer23
Hausbauer23
12 Mar 2025 11:12
Does anyone here have experience with black door handles? As far as I can tell, most of them are powder-coated. Do they really last long-term or at least several years without becoming unattractive? You often see these with interior door suppliers because they can obviously look quite nice...
Tolentino12 Mar 2025 11:16
Our very inexpensive lever handle sets from Hornbach have now lasted 3 years without any signs of chipping or discoloration.
The set screws used to secure the handles seem to be rather small or something similar; they start to become loose after a short time.
I would expect that with a branded and more expensive set, this issue would be better, and the coating would be at least as good.
Our self-painted handle set on the front door (because the original only came in silver or white) unfortunately did not maintain its color well. I will need to consider a long-term solution for that.
In der Ruine12 Mar 2025 12:44
Tolentino schrieb:
Our self-painted fittings on the front door (because the ones available ex works were only in silver or white) unfortunately did not hold the paint well. I will have to think of a long-term solution for that.
For purchased fixtures, I would expect powder coating, which usually doesn’t chip off.
11ant12 Mar 2025 16:00
Hausbauer23 schrieb:
Does anyone here have experience with black door handles? As far as I can see, most of them are powder-coated. Do they really last long-term or at least stay visually appealing for several years?
Even with aluminum front doors, the fittings are not necessarily aluminum as well. Often the levers are, and like the door itself, they are powder-coated and highly durable. However, the pull handles on the exterior are more often made of polyamide with a steel core, and are dyed all the way through. Of course, scratches from keys can occur, but wear does not reveal a different color underneath. Anodized finishes, as far as I know, can only be dark brown at most, but never close to black. For interior doors, if handles are black, they are usually polyamide, with the most common brands on the market being from HEWI.
