ᐅ Regarding the final inspection: does this comply with the electrical standards according to the relevant DIN norm?
Created on: 5 Mar 2024 15:55
Elwood62
Elwood62
5 Mar 2024 15:55
in April, the inspection of my semi-detached house, which I purchased from the developer, is scheduled.
The construction description states the following:
Installation carried out according to DIN 18015-1+2 (electrical system) + standard-enhancing basic installations (“standard equipment” as described in DIN 18015 Part 2)
Maybe someone knows whether this rather amateurish installation for LAN and satellite complies with the DIN standard (see attached).
Or should this be inside the distribution box?
I would appreciate any advice.
Technical room with white cabinet, network equipment, cable clutter and piping.
hanse987
5 Mar 2024 16:37
Is the patch panel grounded? I don’t see anything indicating that.
Otherwise, this is a standard setup like in thousands of homes. What I actually like is the downward-facing patch panel, as it prevents dust from falling into the ports. There is also space to mount devices.
What I don’t see is a fiber optic connection or a telephone socket. Where is this hidden?
k-man2021
5 Mar 2024 18:40
It looks exactly the same as in our case, only the grounding of the patch panel seems to be missing, as @hanse987 has already pointed out.
nordanney
5 Mar 2024 18:51
A potential equalization would be required to meet standards. For this purpose, Telegärtner offers a dedicated—but optional—"set." It should be done (if everything is done correctly), but with these DIY devices outside of a rack, it is actually rarely implemented.
Elwood62
5 Mar 2024 20:01
Thanks for the quick and knowledgeable answers!
The fiber optic modem from the telecom company is still on its way (very closely monitored).
I hadn't even considered the equipotential bonding. I will definitely raise that with the electrician.
And if I understood correctly, placing it outside the electrical cabinet is common practice, which I hadn’t expected.
Alright, then everything is answered. Thank you very much!
hanse987
5 Mar 2024 20:52
Elwood62 schrieb:
And if I understood correctly, placing it outside the electrical cabinet is common, which I wouldn’t have expected.
From my point of view, you should be glad, because multimedia distribution panels are often installed with rather limited space. If you want a proper network cabinet, you need to plan it early and coordinate the interface with the electrician. This is usually not possible with volume builders.
