Two years ago, we moved into our house, including the basement.
In the basement, we created a large room, which at the moment and in the future is divided into:
One side hobby room
One side storage/pantry room
I would like to visually separate both areas. I want to do this properly and am thinking of using drywall with gypsum board panels.
Now to my questions, or rather, I would like to get some advice here:
1. Does drywall make the most sense in terms of price/performance here?
2. I would ideally like to install panels on both sides, but without insulation – does that make sense? It’s meant purely as a visual separation.
3. Regarding the door opening: Obviously, a passage is needed, but it does not have to be a hinged door – maybe a sliding option could work, or possibly just leaving it open, since the doorway area is a nice feature visually and it could also be practical to keep the passage permanently open. Of course, planning a door makes sense for the future, but maybe someone has another idea?
4. I am open to suggestions or tips to keep everything as cost-effective as possible.
Thank you very much!!
One side hobby room
So, everyone, one side of the wall is fully covered, and the electrical wiring has been neatly installed.
Now I'm wondering whether I should insulate the wall at all.
This is just a visual room divider in the basement.
One side is a hobby room, the other a storage room. There is no heating or window in the room...
I don’t really see any benefits to insulating this wall.
What do you think? Can I skip it after all?
nordanney10 Mar 2025 10:58Prager91 schrieb:
Can I skip it, right?Yes. But I still wouldn’t recommend skipping it because you might want to use the rooms differently in the future, and then you’ll appreciate having insulation.See if you can find second-quality or similar options. I’d be willing to spend the €5-7 per square meter (€5-7 per square meter) for it.
nordanney schrieb:
Yes. However, I still wouldn’t recommend it, as you might want to use the rooms differently in the future, and then you’d benefit from insulation.
See if you can find second-grade material or something similar. I’d be willing to invest 5–7€ per square meter (5–7 USD per square foot) for that. I think it will be quite tricky because of the electrical cables and the protruding nails inside the aluminum profile. I would try to avoid the effort and the costs somehow.
Regarding room use, I’m certain: no one will be living here in the future, and a permanent heating system definitely won’t be added later (that’s not even possible anymore...).
We don’t have any windows in this room. It’s really just a hobby or playroom, or something similar. The other side will necessarily remain storage or a pantry in the future.
If anyone is even present at all, it will be on one side only. So, I don’t have any issues with sound, heat, or noise.
But can you think of any other advantage of insulation?
nordanney10 Mar 2025 11:05Prager91 schrieb:
But can you think of any other advantage to insulation?No, absolutely not. If the need can be ruled out, then just skip it.Similar topics
