ᐅ Drywall Mold?
Created on: 21 Feb 2016 18:15
O
oggear51
The cement screed has been installed for about three weeks now, and small black spots are gradually appearing on the drywall panels upstairs.
Ceiling with stains, flaking, and white plaster areas.
Unfinished plastered ceiling with white filler spots and circular markings.
Green drywall with many white filler spots at joints and corners.
Room ceiling with leftover filler and a hanging white cable line.
Is this mold? It looks like mold to me.
O
oggear51
22 Feb 2016 00:27
The architect told me that I don’t need to ventilate because, in this weather, it would only bring in unnecessary additional moisture, those were his exact words.
Neige22 Feb 2016 01:36
I want to describe this in simple terms. Imagine you are in a comfortably warm heated bathroom, filling the bathtub with water, then lying down in it. What happens? The mirror fogs up just when you want to style yourself after a long bath. What do you do? Wipe the mirror, or briefly tilt or open the window? Observe what happens.
Best regards, Sigi
wrobel22 Feb 2016 02:52
Hello
The right solution is / would be to dry the building and, of course, all other areas technically, especially in this kind of weather.
Olli
O
oggear51
22 Feb 2016 05:55
I had insisted on that, but the architect rejected it. I have now sent him a written notice of the defect, asking him to find a solution together with the drywall contractor.
Legurit
22 Feb 2016 07:34
Without heating, ventilation currently doesn’t help much. At 10°C (50°F) outside and 99% relative humidity, you need about 20°C (68°F) indoors to get the relative humidity below 55% (or similar – just Google relative humidity).
The principle is air exchange; ideally replacing warm, moist air with dry, cold air.
Bauexperte
22 Feb 2016 10:11
oggear51 schrieb:
The architect told me that I don’t need to ventilate because in this weather it would only bring in unnecessary additional moisture, that was his exact wording
I see it a bit differently; during the first 1.5 weeks of February, temperatures in NRW were still around ±12°C (54°F). At that time, airing out the building by opening windows briefly would probably have been beneficial. After that, technical drying should have been used until the heating program started.
The more interesting question, however, is: do you have the architect’s statement about ventilation/drying not being necessary for the new building in writing? Otherwise, it will certainly become an issue when it comes to covering the costs.
Regards, Bauexperte
