ᐅ Which tool is best for adding a house to a site plan?
Created on: 19 Aug 2021 15:25
Andreas_79
Hello everyone
I have now received the surveyor’s plan.
1x PDF and 1x DWG file.
Everything in 2D.
Now I would like to draw the house on it so I can better see the distances and size.
Which tool would be best for this, preferably free or with a trial version?
Regards
Andreas
hanse987
19 Aug 2021 18:50
Pencil, set square, and a calculator for converting measurements if the printout is not to scale.
K1300S19 Aug 2021 19:52
If you already have a .dwg file, you can use LibreCad, FreeCad, QCad, or similar software. These allow you to draw accurately to scale.
bauenmk202021 Aug 2021 08:18
Based on my own experience, I would recommend starting the whole process with an "architectural software." I use "cadvilla," which is a user-friendly architectural program for non-professionals but delivers quite good results.
I also started with the DWG plan and imported it. I roughly modeled the neighboring houses, the street, and the sidewalk. I included contour lines and elevation points. You can import furniture from 3D Warehouse. For example, I also imported my own models from FreeCAD. I even did the electrical planning within it.
If you enjoy fully modeling your house, I can definitely recommend this approach.
tomtom7921 Aug 2021 08:20
Sure, just like that, you can learn the basics in a few hours.
Andreas_79
24 Aug 2021 10:29
Thanks a lot, I used QCad to display the measurements and then switched to graph paper and pencil. It worked well :-)
