ᐅ Drainage channels in front of patio doors
Created on: 24 Feb 2019 17:59
m-i-s-c-h-a
m-i-s-c-h-a
24 Feb 2019 17:59
We have three large sliding doors from the living/dining/kitchen area to the terrace. The terrace is partially covered by a balcony (with its own drainage). One door is protected under the balcony, two doors are uncovered. The terrace will be connected with a barrier-free threshold (less than 2cm (0.8 inch) step).
Do I need a drainage channel in front of only the two uncovered sliding doors, or also at the sliding door under the covered balcony?
Thank you in advance.
rick201824 Feb 2019 22:25
According to the standard, this applies to uncovered areas.
For covered areas, it depends on the type of covering.
Everything can be arranged individually if you don’t want a gutter. But then don’t complain about problems afterwards.
The gutter must be 15 cm (6 inches) wide.
