ᐅ Flooring for a Double Garage – Screed with Two-Component Coating? Epoxy Resin
Created on: 18 Oct 2019 18:25
Kevinius
I am considering having fiber-reinforced screed with a slope installed in the garage. On top of that, a two-component epoxy resin coating—that would actually be my ideal solution.
What are your experiences with epoxy resin coatings? How durable are they?
How does the material hold up if a tool or part is dropped on it? Can it be repaired easily?
We have a raw concrete slab that is 15cm (6 inches) thick.
The area is approximately 70m² (750 square feet).
Regards
tomtom7922 Oct 2019 08:24
Kevinius schrieb:
What happens to the water running off the car then? Road salt?
The concrete slab probably won't like that over time.
There won't be a concrete slab here. The water will soak directly into the ground.
Bookstar
22 Oct 2019 08:28
Yes, this is without a concrete slab. However, it has many disadvantages: it is difficult to keep clean, the paving settles and becomes uneven, and oil stains are hard to remove. It is basically the low, low budget solution.
Grantlhaua
22 Oct 2019 08:36
Kevinius schrieb:
What happens to the water running off the car? Road salt?
The concrete slab probably doesn’t like that over time.
That’s why we don’t have one. We only have a ring beam on which the walls stand, and the area is covered with gravel and lean concrete. So the water can infiltrate freely.
@Bookstar
But there are also many advantages. Everyone has to decide for themselves. For us, it wasn’t a financial decision but one of principle.
Kevinius26 Oct 2019 12:04
That’s not an option for me, as Bookstar has already listed quite a few points.
I would prefer a smooth floor that can be easily cleaned with a squeegee.
It will probably come down to 2K resin (on screed)... that seems to me the best option.
readytorumble
26 Oct 2019 12:23
We also had a professional apply a two-component epoxy resin in our double garage.
Directly on the concrete slab, without a screed.
I would do it the same way again.
Bookstar
26 Oct 2019 19:32
readytorumble schrieb:
We also had a professional apply a 2K epoxy resin in our double garage.
Directly onto the concrete slab, without a screed.
That's exactly how we did it too.
